Fluid Leak
Old Feb 26, 2010 | 11:25 AM
JagV8's Avatar
It's empty, Rick!
Old Feb 26, 2010 | 11:39 AM
Jon89's Avatar
Nah, the ghost of Oral Roberts is on the case. I conjured him up for Rick. "HEAL, thou nasty leak, HEAL!!!!"
Old Feb 26, 2010 | 06:22 PM
joycesjag's Avatar
Originally Posted by jagv8
It's empty, Rick!
Touch'e !!!!
Thank you for the conjure sir!!!
So far so good though<---I guess I am really trying to jinx myself.
Old Feb 27, 2010 | 07:23 AM
Jon89's Avatar
If you had a very tiny leak from around that transmission pan O-ring sleeve that a couple of guys here on the forum have replaced recently, I wonder if settling debris may have floated over to that area and solved your problem, at least temporarily....
Situations like this one are a perfect example of why this ZF transmission (and ALL transmissions) need a dipstick (which also serves as your fluid fill tube). Right now you have no easy way of determining the level of your fluid or its condition. Bummer....
Old Feb 27, 2010 | 09:17 AM
ccc's Avatar
ccc
With regards to the ZF leak, mine dripped oil once (that I know of) on the garage floor then didn't leak at all for the next several weeks (this is with a 120 miles round trip commute to work). I think there is another member that also saw the same thing. In both cases, when it does leak, it isn't just a few drops but in my case, it was enough to run down 4 or 5 feet inside of the garage. The ZF sleeve leak can drive you crazy, don't know if its leaking when your driving or how much fluid is really left.
If its the sleeve and you don't feel like jacking up the car, you can slide a observation mirror under then car and look near the rear of the transmission on the passenger side for any fluid dripping. If anything looks wet, especially the rear transmission mount rubber, then its likely the connector. If your really want to check under the car, you can remove the connector and check if you have fluid inside. In my case, the leak was from inside of the connector sleeve so I think quite of bit of fluid needed to build up before it would leak out of the mated pair.
Old Feb 27, 2010 | 05:15 PM
joycesjag's Avatar
Thank you ccc, I know I need to just order the part and get under there. But all this "warming up" and shifting through the gears checking temperature blah blah blah and blah...... I need to drink some beers and "Just say YES!!!!" I will be following your very informative FAQ, and again thank you for that!
Old Apr 12, 2011 | 12:41 AM
jsampson's Avatar
Default Pin Hole Coolant leak
I have been observing a small BB size organge goo leak from what looks like its coming from the center of what looks like the thermostat housing. Any idea of what is going on? Should I replace this piece?
Old Apr 12, 2011 | 05:49 AM
  #28
JOsworth's Avatar
Hard to tell from that brief description. I would post up a picture.
Old Apr 17, 2011 | 12:33 AM
jsampson's Avatar
I found the small pin hole leak on the plastic thermostat housing (it actually looks like a needle went through it). Thats the problem. I have the part, but no gasket. Should I replace the thermostat while I'm at it? Can I make a gasket, or use an OEM part (probabaly dumb question)?
Old Apr 17, 2011 | 02:08 AM
  #30
bogart's Avatar
Is there a trans cooler in the main radiator? (I've not traced pipes yet LOL)
Certainly is in the 3.0L so assume that 4.2 is no different. So one can get transmission fluid leaking anywhere from radaitor to rear of pan. Odd it's pink but that could be due to someone having changed it as previously mentioned. Strange that you say the coolant dried to a pinkish colour, how confusing.
Old Apr 17, 2011 | 02:15 AM
  #31
bogart's Avatar
C'mon go for it you know you want to do it. Not hard once you set your mind to it. then you can celebrate with beers after
Old Apr 17, 2011 | 08:40 AM
  #32
Hi Bogart,
If you check the original post date and Ricks other posts you will see that the celebratory beers have long since been recycled.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
sogood
Sep 15, 2015 07:35 AM
Richard_gib
Sep 12, 2015 07:08 PM
