Gearbox
Old Oct 6, 2021 | 10:03 AM
David1960's Avatar
Default Gearbox
Hi I have a s type 3 liter v6 auto great car but I have two problems there is a clunking noise from the passenger front wheel area when I go over a bump any ideas? Also at time when I pull away the auto box does not like to change into second from first if I excelerate quick to about 30 mph it changes to me this is not right.. but may be it is Amy ideas thank David
Old Oct 6, 2021 | 10:33 AM
Welcome to the forums David,
I've removed your duplicate of this post. I'll leave it to the S-Type experts to advise on these technical issues.
Old Oct 7, 2021 | 06:44 AM
S-Type Owner's Avatar
On the "clunk," best get the car up on a rack to check for loose/worn suspension components. As far as the odd shifting pattern, the S-type was fitted with two different transmissions during its production life; start of production thru 2002.5, was a 5 speed Ford unit and from that point to the end of production was a 6 speed ZF unit. What model year is yours, how many miles are on the car and has the transmission ever been serviced... ?
Old Oct 7, 2021 | 07:04 AM
David1960's Avatar
the car is 2004 5 speed 98000 miles and as I have only had the car for a short time I am not sure if its been serviced the mechanic said change the old and filter etc should help
Old Oct 7, 2021 | 05:55 PM
JagV8's Avatar
It's a 6 not 5 speed
ZF 6HP26 trans
Old Oct 8, 2021 | 08:52 AM
AT 98K, if the transmission has not been serviced, it is long overdue. Make sure that you use the correct ATF, Jaguar branded or ZF lifeguard-6, and not some purportedly "multi-brand" brew and says it covers a range of vehicles.
Old Oct 8, 2021 | 09:37 AM
clubairth1's Avatar
Community Influencer
Welcome David1960!
Please get familiar with the search function as all your problems have been posted before.
Really is a lot of info already posted as these cars have been on the road for many years now and pretty much all the problems have been revealed and solved some time ago.
Also use Mercon SP for the transmission. This is the exact same fluid as Lifeguard6 but is red and bottled in Houston,Tx.
Way cheaper and much easier to get.
Old Oct 13, 2021 | 04:15 PM
iansane's Avatar
In regard to your clunking, I found that the bushing the strut bolted to was deteriorated on my car to the point it would knock and rattle at low speeds. You can buy just the bushing and press it in to the old control arm or since you're in there, replace the control arm itself to get new bushings at either end as well.
It's a good idea to get it in the air and check swaybar endlinks, control arm(both upper and lower) and strut mounts as well.
suavegarve
Mar 13, 2014 05:17 AM
wearlej
Feb 25, 2014 04:53 AM
Fermanaghman
Dec 18, 2012 08:11 PM
easydriveways
Aug 31, 2012 08:14 AM
