headlamp repair
Old Jun 27, 2012 | 11:50 AM
mikewv100's Avatar
Default headlamp repair
I had all of the adjusters broken in both of my headlamps. I baked them for 10 minutes at 175 and they came apart easily. I got rid of all of the sealant holding the lens to the rear of headlamp. What is best adhesive to use to reassemble the headlamp?
Old Jun 27, 2012 | 04:02 PM
abonano's Avatar
You should be able to spread some of the original sealant towards the rear part of the headlamp. It's also evident in the crevices. Bake them again @ 175 degrees for 5 - 7 minutes and push them back together tightly. As they cool off they will seal. No need for any adhesive. (Thanks Brutal!)
Old Jun 28, 2012 | 12:40 PM
mikewv100's Avatar
I guess I should not have spent an hour getting all of the old sealant out. By the way. The replacement adjusters are much better construction than the originals. I can see why they all break. Jaguar should be ashamed for this part.
Old Jun 28, 2012 | 12:48 PM
JagV8's Avatar
It's not a part made by Jaguar. I understand it's Hella. They make them for lots of cars...
Old Jun 28, 2012 | 01:34 PM
cbharley10's Avatar
Default Replacement Adjusters
I didnt know you could get replacement adjusters?? I used the old screw through the front plastic between the lights and that did the trick raising mine back up. I would be interested in repairing mine if I could find the adjusters!!
Where in the world did you locate the replacements!!???
Old Jun 28, 2012 | 04:23 PM
abonano's Avatar
The adjusters could be found on Ebay - these are made privately. I've installed them. MUCH BETTER quality!!! Link is below. Well worth the $105.00
Jaguar S-type S type NORMAL/ XENON headlamp headlight repair kit adjuster 2 SETS | eBay
Old Jun 29, 2012 | 03:16 PM
mikewv100's Avatar
Default Adjuster come from Poland
Quality is way better than Hella. They have metal inside with a plastic overlay. Fit perfectly. There are 3 adjusters per side. The screw will not work when all of them are broken. The oven is very easy to use and the adjusters are easily changed. I have mine apart. PM me if you need pics of dissasembled headlight
mikewv100
Old Jul 3, 2012 | 03:50 PM
JbB's Avatar
JbB
I don't need to do this fix, but I'm curious about removing the headlights. I know the process, removing the front bumper, etc. But yo, that seems like such a HUGE process. Seems like a lot of you have done it. What's your take on the process? How hard is it really?
Old Jul 5, 2012 | 08:41 AM
mikewv100's Avatar
Default Front Bumper removal
Not near as difficult as it sounds. I have never done before. Took an hour
Helps to have a drill with a socket attachment to get bolts out quicker.
Old Jul 6, 2012 | 03:31 AM
JbB's Avatar
JbB
Hmm, good to know. Thanks for the info.
Old Aug 7, 2012 | 01:05 PM
Glyn E's Avatar
mikewv100
hey Mike, could you send me a link to the headlight pictures please? A short description of how to remove them would also be really useful.
Thanks, Glyn
bdboyle
Sep 16, 2019 05:58 PM
Woznaldo
Sep 26, 2015 11:02 AM
reb1999
Sep 26, 2015 08:41 AM
redgear
Sep 26, 2015 07:21 AM
