HELP- FAILSAFE ENGINE MODE LIGHT ON
Old Dec 25, 2008 | 08:08 PM
Francesca's Avatar
Default HELP- FAILSAFE ENGINE MODE LIGHT ON
Of all days my Jag would have to break down in the middle of nowhere- it happened yesterday, Christmas day,after the "Failsafe Engine Mode" amber light came on- proceeded to drive with caution (unsure of what may be wrong) until the red failsafe mode light came on and I limped a long way before it just wouldn't go.
I checked the owners manual and it said mechanical or technical fault usually- has anyone experienced this before and what was the cause ?
Old Dec 25, 2008 | 10:49 PM
Brutal's Avatar
Default RE: HELP- FAILSAFE ENGINE MODE LIGHT ON
it can be many things from misifres excessice, to brake switch, throttle body, gas pedal, trans malfunction and on and on. but when this happens the best thing you can do is pull over, shut it off, and restart, if it doesnt see the fault again it will drive normally again, if it does it will reset limp home again as soon as it sees the fault again. you need to see what codes are retained and then go from there with diagnostics and repair
Old Dec 26, 2008 | 04:37 AM
Francesca's Avatar
Thank you so much for your encouraging diagnosis- let's hope it is nothing too serious, as we all know these Jags can suck you dryWill let you know what they find !
Old Dec 27, 2008 | 09:28 AM
sian123h's Avatar
Hi
I had this problem mid december, it didn't break down, but I pulled over andcalled the RAC. the engineer put it on his laptop but could find no fault and when the car was started again, no warning message.
Then on christmas day, happened again. intermittent warning message for about 24 hours and now fine again. I have noticed that one of my brake lights in off/on faulty.
Could this be the cause?
Old Dec 27, 2008 | 09:42 AM
Brutal's Avatar
ORIGINAL: sian123h
Hi
NO, you need to have codes read, and if for some reason its not retained(unlikely, but does happen) then you need to drive to get it read without shutting off key while still in failsafe mode.
Old Dec 27, 2008 | 12:25 PM
sian123h's Avatar
Thanks for that quick reply. Any ideawhere would I get the codes read in the UK, without it costing me an arm and a leg?
Old Jan 1, 2009 | 01:53 AM
Francesca's Avatar
I took it to the mechanic and he put it on the diagnostic machine and it showed up that the Throttle Pedal Sensor had an issue- they cleaned it and did a few things to it and it is absolutely fine now.....thank god !
Shawn Svacha
Nov 4, 2019 02:47 PM
jehart49
Sep 12, 2015 05:36 PM
lee,lee
Aug 31, 2015 04:35 PM
roumor
Aug 28, 2015 01:02 PM
daro31
Aug 27, 2015 09:26 AM
