Help identify a hose please!
Old Sep 28, 2011 | 06:38 AM
dougd's Avatar
Default Help identify a hose please!
Hi everybody,
I have 2003 Jaguar S-Type with a 4.2 V8. I recently changed a cracked thermostat housing and in the process broke the plastic host that connects between the Mass Airflow and the passenger side valve cover. Can someone tell me what that hose is called or provide a part# so I can replace it? I taped it temporarily but I'm now getting MAP faults and suspect this broken hose may be the problem. Thank you very much for your help!
Old Oct 1, 2011 | 08:21 PM
ispkarl's Avatar
Dont you mean the "breather hose" from the air intake tube to the driver's side cam cover ??
Old Oct 1, 2011 | 08:43 PM
joycesjag's Avatar
Possibly the "camshaft vent tube", contact Nalley Jaguar, they are a forum sponser and will fix you right up.
PS make sure you tell them you a jaguarforums member and you will receive a discount!
Old Oct 4, 2011 | 06:29 AM
dougd's Avatar
Thanks for the replies! I think this is more like a PCV hose. It connects between a round valve looking part on top of the passenger side valve cover and the mass airflow. It was made out of a rigid plastic. I'm getting MAP faults and the 'Restricted Performance' indicator light. Thought maybe my tape repair wasn't holding and causing the MAP faults.
Is Nalley Jaguar in Atlanta?
Thanks again!
Old Oct 4, 2011 | 07:13 AM
joycesjag's Avatar
Yes Nalley is located in Atlanta. If the following picture is correct, email Dan or Mike @ Nalley.
Old Oct 20, 2011 | 06:23 AM
dougd's Avatar
Thanks everybody for your input! I also want to give a big thanks to Dan Wicker at Nalley Jaguar in Atlanta. He was able to identify the part and even shipped them to my house in Indiana for a discounted price.
Now I just need to install it this weekend and see if my MAP fault goes away.
Thanks again!
Old Jan 14, 2020 | 06:46 PM
carzaddict's Avatar
how old are the tires? i have a similar issue with my XJ that had flat spotted wheels....got new wheels and still had vibration...did all the balancing, everything checks out....finally did roadforce balancing and found that the (brand new) tires were measuring higher than normal. something to consider
Old Jan 14, 2020 | 07:13 PM
Catfan01's Avatar
I know we have blamed some of these off the wall posts on the "Related thread" feature...
How does this relate?
Old Jan 14, 2020 | 09:02 PM
motorcarman's Avatar
I am related to most of the people in my family. I have bounced 'off-the-wall' at times.
That is how I relate!!!
bob
Old Jan 20, 2020 | 01:25 PM
clubairth1's Avatar
Community Influencer
Yep. Related Threads strikes again!
I know I have been guilty of this too. It's just too easy to get off track and answer the wrong thread.
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
