Hood cable
Old Feb 23, 2026 | 02:40 AM
vmaxie's Avatar
Default Hood cable
Hello all
On my 2006 Jag S type the cable that opens the hood snapped.
When I pull on the cable at the hood release inside the car it just pulls right out indicating it snapped.
So how do I get the hood open now? Any help or ideas?
Thxs!
Old Feb 23, 2026 | 03:47 AM
JagV8's Avatar
There are posts to show you, might have to Search using bonnet
Old Feb 23, 2026 | 04:55 AM
kr98664's Avatar
These links should help:
https://www.jaguarforums.com/forum/s...-broke-226658/
https://www.jaguarforums.com/forum/s...-cable-175675/
https://www.jaguarforums.com/forum/s...-s-type-65618/
Please note the differences between the early and late models. You will have to sort through the threads above to find details applicable to your model.
Old Feb 23, 2026 | 10:26 AM
gunnerman's Avatar
Mine broke on one side on my 2003 S-Type 3.0. I discovered I can reach in from the lower bumper "scoop" thing and actuate the release with my finger. You may need to remove the black center piece in the scoop first.
On your '06 the front bumper, anti-theft (if equipped, mine is not), etc. may be different so YMMV.
Old Feb 23, 2026 | 11:55 AM
scottjh9's Avatar
When my broke i got a long skinny screwdriver at harbor freight. It is about 24 inches long. Flat head. Then cut a v notch on the blade and came thru the grill and pushed the latch to unlock. I got lucky on my cable as it broke right on the connector end. I was able to crimp an eyelet onto the existing cable and use a small bolt and nut to secure. Still holding. The complete cables are hard to find. I think i finally found a good used one from jagbits as backup. If you need replacement check them first
Old Feb 23, 2026 | 12:24 PM
kr98664's Avatar
Wow, that is one tiny store! My local HF is probably 150 feet long at least, although I’ve never measured it.
Old Feb 23, 2026 | 12:29 PM
scottjh9's Avatar
Karl. You always amaze me
Old Feb 23, 2026 | 04:15 PM
gunnerman's Avatar
I found a complete one at a local U-Pull-and-Pay but I decided I couldn't be bothered to fix it. I just decided to keep doing the reach around.
Old Feb 23, 2026 | 05:53 PM
scottjh9's Avatar
that was a good find
Old Feb 24, 2026 | 09:14 AM
JFSTANG's Avatar
i've always been a bit paranoid about snapped hood cables on all my cars. Whenever a hood is opened, before I close it I always give a shot of lubricant (Krown rustproofing, penetrating oil, etc) into each hood latch and cable assembly, as well as any shifter linkage etc. But things do happen.
Old Feb 24, 2026 | 11:53 AM
scottjh9's Avatar
agree. The weak spot on the cable seems to be where the double l shaped end is crimped onto the inner wire. Mine was down to 2 threads when i caught it. Got lucky
nobody1942
Jul 21, 2024 01:05 PM
goldgun
Jun 6, 2022 10:17 AM
bobsalmon
Dec 20, 2016 04:57 AM
pab
Jun 21, 2011 09:28 AM
