I know cats don't like water but this is ridiculous!
Old Dec 11, 2017 | 04:25 PM
Donna's Avatar
Default I know cats don't like water but this is ridiculous!
OK, so every time I wash the car, or it rains I'll get one, and only one instance of a minute or so of restricted performance... The ubiquitous 0171 and 0174 codes are thrown.
There are no leaks (water in or air / vacuum out) and no concerns at all if I keep the temperamental beast dry.
This one has me stumped. I can reset the codes immediately and it's fine, even if it's still raining and I drive for hours! I have to wait until next time it rains to repeat the problem.
I'm thinking an exorcism is called for.
Old Dec 11, 2017 | 04:29 PM
Busa's Avatar
Have you checked the boot/battery area for water ingress?
Boot : "trunk".
Old Dec 11, 2017 | 04:50 PM
Donna's Avatar
Boot, trunk, back bit of the car is as dry as an englishmans bath mat (no offense )
Airbox also dry, MAF dry, from air filter to throttle body dry (and clean), infact all sensors staying quite dry...
Old Dec 11, 2017 | 04:58 PM
Busa's Avatar
no problem, I'm old enough not to have adjusted to "PC" unless absolutely required. I'm hoping some of the S type seniors will be along soon because I'm still fairly new to mine and learning about the vagaries of the model and brand.
Old Dec 11, 2017 | 05:10 PM
NBCat's Avatar
Check for water entering the cowl area at the bottom of the windscreen causing the loom connections for the injectors and coil units to intermittently work.
Not sure about cats not liking water...
A jaguar in the water searching for prey...
Old Dec 11, 2017 | 05:53 PM
JagV8's Avatar
Look at fuel trims too. Something is wrong and it may even be an air leak.
Old Dec 11, 2017 | 07:05 PM
motorcarman's Avatar
Here is some North American TSB info. May or may not be relevant.
Water Entry TSB seems to be in the same area for many faults.
bob
Old Dec 26, 2017 | 08:24 PM
Donna's Avatar
Hiya,
Yup, was a water leak around the base of the windscreen, lower left side. Sealed and fixed
Donna
Old Dec 26, 2017 | 10:47 PM
kr98664's Avatar
Hiya,
Yup, was a water leak around the base of the windscreen, lower left side. Sealed and fixed.
Groovy! Thanks for the ever-important update.
Updates like this are so important, I'm putting together a crack team to track down forum members that never post any updates. We will find recalcitrant members and subject them to public shaming until they update their threads. We'd have vests and ID badges so it would be all legit. Who wants in?
quaker13
Aug 25, 2011 02:03 PM
exexpat
Apr 16, 2011 01:02 PM
maikal_0011
Jul 8, 2010 07:46 AM
jvegas
Jul 12, 2008 09:35 AM
