Intake Manifold Problem!!
Old Nov 14, 2011 | 06:26 PM
cue244's Avatar
Exclamation Intake Manifold Problem!!
So this past weekend I tried doing some maintenance on my 2001 S-type. I tried to remove the intake manifold and one of the bolts is stripped and will not come out!! I spoke with someone at a Ford Dealership and he stated that in the past they had to buy a new manifold. Is this true? If so, anyone know where I can get one?
I found this one (but it is from overseas and I haven't bought something like this):
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Thanks!!
Old Nov 14, 2011 | 06:45 PM
cue244's Avatar
Opps I need the part below the part listed above!! The black plastic piece.
Old Nov 14, 2011 | 06:52 PM
Which bolt is stripped? Do you have a picture?
There may be options for repair once we can see what's broken.
Old Nov 14, 2011 | 06:57 PM
cue244's Avatar
Okay I will post one for sure. I am working the Fire Station today and for some reason Photobucket is blocked, so I will in the morning.
Old Nov 15, 2011 | 03:19 AM
JagV8's Avatar
Others have had similar-sounding trouble, I think (not my engine so didn't take a ton of notice at the time). Sometimes you can get a bolt/insert out and re-tap or even glue. Have a search of the forum but also try www.jaguarforum.co.uk
Wreckers (scrap yards) will have the parts, you won't need to buy overseas. There are web sites where you input what you want and get back emails offering them. You do need to ask for the right part
Also, check ebay for anyone breaking the equivalent car (1999-2002, dunno if it changed after that).
Old Nov 15, 2011 | 08:09 AM
Brutal's Avatar
Just pull the intake up with all but that one bolt removed. The brass insert will come with it. Then take pliers and hold it and unscrew the bolt. It just came unseated from the plastic fuel injection manifold. Epoxy the insert back in the hole with plastic epoxy. Do not use jb weld it doesnt stick to plastic. Make sure you do not get excess epoxy in the threads. Then when you bolt it down put the other bolts in first and put alitttle lube on that one and easily snug it. Youll be fine, fix these like this all the time. Welcome to the wonderfull world of plastics
Old Nov 15, 2011 | 02:36 PM
cue244's Avatar
Size:  22.7 KBName:  manifold1.jpg
Thanks for the tip!! I will give it a shot and see what happens!
Old Nov 15, 2011 | 02:37 PM
cue244's Avatar
Oh ya, what are the equivalent cars? I read Lincoln LS I think.
Old Jan 9, 2012 | 09:41 AM
Brutal's Avatar
A hi strength plastic/metal epoxy. Not jb weld metal epoxy permatex makes a good one and no need for hi heat, its not that hot
Old Jan 9, 2012 | 11:21 AM
Bacardi 151's Avatar
If you're manifold pressure gets too high, you risk losing your passenger side floor pan...This is according to the Fast and the Furious...
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
joesoap
Sep 10, 2015 01:09 AM
