jag s type top hose problem ??
Old Feb 9, 2016 | 11:40 AM
jagman700's Avatar
Default jag s type top hose problem ??
Found split in top hose hence losing water Replaced hose its happened again replaced again happened again Then find out the hose supplier is giving me non genuine hoses The question is are genuine hoses a lot stronger or is it another problem Cheers Sean
Old Feb 9, 2016 | 12:01 PM
Sean - I've moved your post from the Forum Feedback & Suggestions section (which is for issues related to the forum itself) to the S-Type section specific for your model.
Old Feb 9, 2016 | 12:37 PM
Originally Posted by jagman700
Found split in top hose ......
Sean,
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 9, 2016 | 06:32 PM
car5car's Avatar
If plastic coolant bottle cap is clogged, system pressure can be too high.Normal pressure is about 16 PSI, aftermarket hoses hold it fine.
Old Feb 9, 2016 | 07:00 PM
I agree, pressure cap is way up there on my list.
Never had issues with aftermarket hoses ever.
Jag dont make them anyhow, it is a Brand name manufacturer (Gates etc) that does that for ALL car makes out there.
Old Feb 9, 2016 | 10:37 PM
abonano's Avatar
Gates is a reputable brand...
Old Feb 9, 2016 | 11:10 PM
kr98664's Avatar
Here's the upper hose (URO brand) I recently installed in my '02 V6. Works great, no problems. The plastic Y-fitting in the middle looked like it came from the same mold as the existing (OEM?) piece:
http://www.amazon.com/URO-Parts-XR827648-Upper-Radiator/dp/B0066STTKM/ref=au_as_r?_encoding=UTF8&Make=Jaguar%7C20&Model=S-Type%7C93&Year=2002%7C2002&ie=UTF8&n=15684181&s=automotive&vehicleId=3&vehicleType=automotive http://www.amazon.com/URO-Parts-XR827648-Upper-Radiator/dp/B0066STTKM/ref=au_as_r?_encoding=UTF8&Make=Jaguar%7C20&Model=S-Type%7C93&Year=2002%7C2002&ie=UTF8&n=15684181&s=automotive&vehicleId=3&vehicleType=automotive
Old Feb 10, 2016 | 05:53 AM
Same as my 2 that I fitted.
The people that make any component sell them primamrily to the OE Customer, and then the excess, and there is always excess, goe to the aftermarket labels.
Been that way the 52 years I beed in Spare Parts.
When the OE parts dry up, usually 5 years after production ceases, unkess that part carries over to the next model, the aftermarket takes over, simple, and it works well down here.
Old Feb 10, 2016 | 09:05 AM
car5car's Avatar
My local junk yard is reputable brand for me.
I paid $2 for Mercedes radiator hose ($60 in local stores)
$40 for Jag like new radiator.
They are expensive cars to maintain!
Old Feb 10, 2016 | 10:24 PM
abonano's Avatar
That's like putting a "Family Dollar" brand band aid on an open wound....
Old Feb 11, 2016 | 09:13 AM
car5car's Avatar
That is why you should always buy parts from a Jag dealer.
Old Feb 11, 2016 | 08:29 PM
abonano's Avatar
Not me.. I get my parts from eBay or Amazon...
Old Feb 14, 2016 | 09:56 AM
clubairth1's Avatar
Community Influencer
Hoses are a wear item. Do not buy them used. Get new only whether factory or aftermarket. Some stuff is factory only.
Old Feb 14, 2016 | 03:19 PM
abonano's Avatar
Agreed. I always buy new. Sometimes I luck out and find new stock OEM parts on eBay at a steal...
anONYMOUSdroid
May 4, 2016 04:53 AM
isaacfornari
Feb 9, 2016 12:31 PM
gmcgann
Jan 23, 2016 05:44 PM
Tirefriar
XE ( X760 )
Jan 12, 2016 09:05 AM
Craig Revolt
Jan 11, 2016 10:31 PM
