Jaguar 's' type Auto box problem
Unfortunately sarcasm happens in all forums I've have been on. Just let it go and move on. But, back to your problem, you changed the fluid and flushed the transmission as I suggested early on. Didn't fix the problem, but needed done anyway. Next as suggested above is to find out if codes are set. My guess now would be a failing module. Codes may give a clue as to which one. When you turn the ignition off and the back on, it is like a computer or router reboot. Get the codes read, if you don't have a reader it shouldn't cost much just for that.
I am blaming the transmission as if the car is in drive and theres a problem with the box then I'm thinking it could 'drag' the engine down? Just trying to solve what's going on. Also when I select n whilst moving then back to drive problem seems to rectify itself for a few miles. As stated, car drives then seems to die, either give it more revs, kick down then drive is presumed or select neutral then back to drive. Either problem with engine or box. Is any of what I'm saying possible? There's no engine or auto box codes lights on dash.
Most gearbox faults flag codes. No codes usually means it's not a gearbox fault, though you can have marginally low fluid. Even a $5 OBD tool can read the 1998-2002 (USA) codes. Most common fault is failing battery or other fault causing poor power. Next most common may be the stretched shifter cable.
Complaining about sarcasm etc when someone can't be bothered to find out and post the codes strikes me as daft. You want help for free - post the data.
This is the obd2 reader I purchased http://m.ebay.co.uk/itm/271586760797?txnId=1453430975017
Received 2,255 Likes
steven_mckinlay (03-30-2015)
#28
I bought this one and its worked like a charm!
OBD 2 II Diagnostic Scanner Scan Tool Machine for Car Vehicle Android Windows | eBay
2000 Jag S type 4.0L
#31
Hi jagv8, would you by chance know which cheap obd2 scanner will work with my 2001 jag stype as I bought one but it does not communicate with ECU. I believe I need the correct obd reader with the correct protocol and pins... But after searching eBay and forums, I cannot decide which one will do as most comment say any of the cheap obd2 will work but these guys have 2002 jags or newer and that's the problem mines is pre2002. Is it obd eobd obd2, the one I have is advanced obd2 which is Bluetooth and using apps on my phone/tablet like torque but just doesn't speak to car. Even though no engine or autobox warning lights are on, I'd like to see live data etc. See if can see a problem that isnt getting flagged.
This is the obd2 reader I purchased HH Advanced ELM327 Torque Android Bluetooth Car OBD2 Auto Fault Code Tester | eBay
http://amzn.com/B00C2FKPCY
It reads reliably and doesn't set a false P1642 like many cheap scan tools do.
Good luck
steven_mckinlay (03-31-2015)
#32
#33
#34
ElJaguar (05-25-2015)
#35
_____________________
2000 S-type Sport 4.0L 5R55N
1976 XJS 5.7L Turbo350 - sold
Terrance Williams
08-26-2015 11:50 AM
