Key problem
Old Sep 23, 2014 | 04:55 AM
ekselman's Avatar
Default Key problem
I have 2002 s type in Australia. Cannot open truck glove box OR DOOR with key only with remote. Key works ignition OK.Truck works from remote also but glove box in front console is locked. Can't open it to get out manual. Just bought car from the bush and only one key. Thought I might have a valet key? did 2002 get supplied with Valet keys in australia.
My 2000 s type was supplied new with 2 keys . both do everything but when i pealed Jag logo off the key it said VALET. The car key that i have for 2002 also says valet but will not open door. any advice on how to break into glove box where manual is and who makes keys.
Old Sep 23, 2014 | 05:05 AM
JagV8's Avatar
Don't break in. Do get a proper set of (two) full keys. They will then open everything.
Old Sep 23, 2014 | 04:05 PM
ekselman's Avatar
Default Keys
new sets of keys in australia could cost a lot of money. Got quote from Jag dealer for 1 key and remote for $800. Strange thing is my other Jag keys S type 2000 4Lt are marked Valet however open all things and .car manual refers to 2 sets of keys and remotes and no mention of valet key. Maybe in Australia we didn't get valet key. The 2000 jag and the 2002 both keys are exactly the same length. I had read that valet key is shorter. Local locksmith looked into computer and said he believed that my 2002 key was main key Not valet key. But we cannot open anything with it. But it works ignition. To open anything must use remote. So it seems that I still have no choice but to break into the glove box in front of passenger Knees. Help.
Old Sep 24, 2014 | 10:35 AM
Sonspit's Avatar
None of my.keys open my doors niether just the button.. Im starting to realize my s type has alot of problems.
Old Sep 24, 2014 | 02:14 PM
The valet key should have a green head the others black, in the US anyway.
I wouldn't want to be without a key that opens the door.
You can convert a valet key to a regular key with a little filing IIRC.
Old Sep 24, 2014 | 03:07 PM
JagV8's Avatar
I like one that opens the boot (trunk) - where the battery is!
Old Sep 24, 2014 | 03:21 PM
Well that's the back door isn't it?
Old Sep 24, 2014 | 03:49 PM
Gus's Avatar
Gus
This sounds like a car that had the ignition lock changed and it was not keyed to the car. You may need to get the key from Jaguar and get the ignition keyed to the rest of the car. If I recall Jaguar will cut a key based on the vin number of your car.
Old Sep 25, 2014 | 12:54 PM
NikolaiDiqnov's Avatar
I would also say that the ignition lock was changed some time ago. If you have a locksmith around you that is not a Jaguar dealer, call him to take a look. I do not know how prices go in Australia, but probably the locksmith will charge at least half of the amount, the main dealer asks.
Old Sep 25, 2014 | 04:03 PM
Donna's Avatar
G'Day mate,
I had a similar problem, with an easy fix... All the key locks were full of dust and gunk... Appears the car had always been opened by the fob and never by key. A lot of WD-40, careful pressure and the use of a small flatblade screwdriver eased all the locks open and now all work just fine.
Once working, I cleaned them out with and used a littel graphite powder to keep them open.
Cheers,
Doug
Old Sep 25, 2014 | 05:11 PM
Gus's Avatar
Gus
That theory is entirely possible; however, to have that key not work in the glove box, trunk and door I am not sure. Good thought!
Originally Posted by dougcthr
G'Day mate,
Cheers,
Doug
dsnyder586
Dec 29, 2024 07:39 PM
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Nov 23, 2015 01:56 PM
My Pham
Sep 4, 2015 03:37 PM
