LED License Plate Lights?
Old Jan 15, 2010 | 05:31 PM
  #61
JOsworth's Avatar
Originally Posted by phd12volt
why does everyone keep saying something about the switch??? i have had them in mine for over a year and it does not have any kind of resister needed whatsoever. Nor switch. Weird that people need switches...........really weird
I know Jason.....
Old Jan 29, 2014 | 05:20 PM
  #62
Wuzupez's Avatar
I know this is an old post but has anyone used the Sylvania 6000k led? They are between $10 & $12 each depending on where you get them from. They seem to be a pretty bright white.
Old Feb 2, 2014 | 10:19 PM
  #63
Wuzupez's Avatar
Ok well I put the Sylvania LED bulbs in my plate lights and it looks perfect. Super happy with the color. Looks factory! However, I did notice a slight buzz after installing them. This normal? I had the car off and and park lights on when I changed them out. After pulling the factory bulbs out and installing the LED's that's when I heard a slight buzzing coming from them
Old Feb 3, 2014 | 11:44 AM
  #64
2000JagLvr's Avatar
I have not installed any LED lights on my car yet so I don't know what they require. Do they need to be installed with the correct polarity? I.E. positive to positive.
Check the connections. Are they clean. The socket may have become corroded over time.
You might have a bad ground somewhere also.
Try re-installing the old bulbs one at a time and see if the "buzz" goes away on one or both. If it is only one bulb try swapping them and see if the buzz moves. If so you might have a bad bulb.
Good luck.
Scott
Old Feb 3, 2014 | 02:41 PM
  #65
Wuzupez's Avatar
It's both bulbs and it's very faint. But it's there. Only with the LED bulbs though. And yes they are the correct bulb #2825
Either way they are staying in cause they look amazing!
Old Dec 21, 2018 | 03:29 PM
  #66
95 Cat's Avatar
My plate light lights do not work either on my 2011 XKR. Dealer says it is a module. A $1,000.00 PART!!!!!!!!! The car is under warranty and I am in the process of getting it fixed. RIDICULOUS!
Old Dec 21, 2018 | 03:42 PM
  #67
JagV8's Avatar
Ancient thread AND the wrong forum
H20boy
Dec 24, 2024 03:23 PM
user 652867429824
Oct 28, 2015 10:18 AM
raffoulig
Sep 8, 2015 01:56 AM
sklimii
Sep 5, 2015 06:04 AM
bdboyle
Sep 4, 2015 06:16 AM
