Line in aux in for stype 2003 with gps
Old Jul 4, 2018 | 12:18 AM
tonimccloud's Avatar
Default Line in aux in for stype 2003 with gps
Good morning,
i have an stype my03 with gps Module, same system as in the photo below
Is it possible to add an aux-in Line-in for my system, in order to listen music via my smartphone?
Regards
Old Jul 4, 2018 | 12:27 AM
Datsports's Avatar
you sure can .
Ben from the UK forum shows you how in this vid -
you can also add the cable to the CD Changer in the boot/trunk . there is a how to some were on here ,
or try to purchase an ACM which is the very expensive factory option . if you can find one .
then there is the less than ideal FM modulated type also .
Old Jul 4, 2018 | 04:32 AM
Thanks for the info datsports. Also I've seen jagdroid mod...incredible! But not for noobs like me
Old Jul 4, 2018 | 06:53 AM
Staatsof's Avatar
My car came with the ACM but mysteriously WO the the USB? I've used it to connect an MP3 player I have and it's great but the interface to operate it from the dash is kludgy, you're simulated as a CD and then you're MP3 player or whatever makes selections via it's system control. Sound quality is first rate though.
It also has an Ipod cable which I tested way back in 2010? and it's kind of funky to operate as well. I used a Sandisk MP3 player.
Anyway, there are plenty of threads about all of this search or Google it. It's dead end technology now that everyone is utilizing bluetooth.
Old Nov 28, 2018 | 09:15 AM
jagadam's Avatar
As i understand it, installing this small machine could be an option PXDXJAG Auxiliary Input Adapter for Select 2000-02 Jaguar S-Type :: Auxiliary Input Adapters
It is however not clear to me if this also works works for the type-s cars after 2002.
Old Nov 29, 2018 | 10:04 AM
JagV8's Avatar
Doesn't look to apply to the very cars which are the subject of this thread!
Old Dec 17, 2018 | 05:47 AM
jagadam's Avatar
I also found this project which sounds quite promising, but I don't know the status of it.
https://www.jaguarforums.com/forum/a...2008-a-184931/
Old Dec 17, 2018 | 11:15 PM
Datsports's Avatar
yes the veff box. i have one . it is a cool bit of kit . but unfortunately no longer available .
Old Dec 17, 2018 | 11:44 PM
Datsports's Avatar
i also have installed one of these . far better sound than a parrot . but not quite as crisp as the veffbox.
it is FM modulated with hands free, and may be the best FM modulated kit i have come across .
its affordable , easy to install .
has bluetooth in .
3.5mm RCA in. male or female.
and RCA in
comes with a flush mount usb charge port . i mounted in the arm rest center console .
mic and cable . it has a switch to internally disconnect the antenna when powered on . to reduce channel interference .
and 3 frequency choices .
https://www.ebay.com/p/Axxess-Mobility-Axm-dc-hf-Hands-Calling-Bluetooth-FM-Modulator-RDS/1330673270
on/ off bypass switch in glovebox
pre programmed banner
hands free mic mounted to roof console
DavidN
Sep 24, 2019 12:33 PM
vdpnyc
Jun 25, 2015 08:52 AM
TallXJDriver
Oct 15, 2013 05:20 PM
Skid Mark
Aug 25, 2011 08:50 PM
FloridaJag
Nov 18, 2009 11:10 AM
