At a Loss
Old Feb 23, 2011 | 10:13 AM
achysklic's Avatar
Default At a Loss
Well I thought I had all of this fixed but after installing a new climate control I found out it's still a no go.
recap:
I replaced the heater valve because it was only blowing super hot air. This fixed the ploblem it now blows regulated heat and cold A/C.
I took apart the climate control it had several burnt traced I tried to repair them. What happened is a little bit of air blew out of the very end vents, no air out of the middle vents, very little out of the defrost. It blew super strong hot or cold out of the rear passenger vents.
I thought the climate control must have a short I missed, so I bought another working climate control and hooked it up. It does the exact same thing.
I am at a loss!
It has to be something that controls the vents, But what?
Please help
I took the glove box out just now and don't see anything unhooked.
Old Feb 23, 2011 | 10:31 AM
achysklic's Avatar
Ok while I have the glove box removed I started car and pressed the mode button on the climate control. I could see the blender motor rods moving with each press of the mode button. I couldn't however hear the blender doors opening and closing. This has me stummped.
Help
Ok I was look at the blender door motor kinda bhind the radio, I think it controls the floor vents cos air is comming out of it. The blender door motor to the right of the glove box is doing nothing when I press the mode button. I bet this is the one that controls the vents. How can I test it?
Ok I think that one is ok as well it is the recirc. motor.
Now on to the next one, is it behind the instrument cluster?
Old Feb 23, 2011 | 11:48 AM
achysklic's Avatar
I checked all the motors except 1. I am pretty sure that 1 is the one I need to replace.
How do I remove the instrument cluster?
I have searched but have come up short.
Any help appreciated.
Old Feb 23, 2011 | 05:16 PM
achysklic's Avatar
Well I finally got the instrument cluster out. If anyone needs to know how just ask. The blender door motor I believe isn't working right. I played with the mode buttons while pushing the vents doors open. They were closed. I got them to open although I was able to get the motor to close the vents it would not reopen them.
I assume a gear is broken on the motor.
I went ahead and ordered a new motor, but I am dreading replacing it.. this is the hardest to get to motor of them all even with the cluster out..
PS if anyone needs a working dual climate control, I have a extra one...lol
Old Feb 23, 2011 | 06:01 PM
Did you take any pictures when you took out the cluster?
I'm sure it would be useful.
Why not list your CCM in the for sale section, some one must need one.
Good luck with the new motor.
Old Feb 23, 2011 | 06:43 PM
achysklic's Avatar
No I didn't take any pics this time, but when the new motor comes in I will do a step by step change out with pics.
Old Feb 23, 2011 | 07:51 PM
joycesjag's Avatar
achy, pics and a small write up would be great! Sorry that there were no helpful replies to what you were doing or asking, I believe you are undertaking virgin grounds. I hope you get your project buttoned up in no time.
Old Feb 23, 2011 | 08:04 PM
Gus's Avatar
Gus
I am sending you both the same message. I think you are both working towards the same resolution and could be comparing notes. You both have a lot of help and may be on a solution soon I hope.
https://www.jaguarforums.com/forum/s...ad.php?t=50343
https://www.jaguarforums.com/forum/s...t=49227&page=5
I am also going to attach the little information I have that may or may not help. http://www.gusglikas.com/AutoRepairAC2000SType.htm You have a great resource on this forum and they are all willing to help.
I will to continue to follow your tests and solutions. Good Luck!
Old Feb 24, 2011 | 05:45 AM
bfsgross's Avatar
Achysclik, I may need a DCC module. Been following your thread but wasn't able to offer additional help. You are brave and resourceful to attempt the repair and have moved through the paces wonderfully.
jagtoes
Apr 22, 2016 07:37 AM
ryan_border
Dec 23, 2015 04:27 PM
millertic
Sep 30, 2015 08:11 PM
Wolfy
Sep 11, 2015 06:27 AM
