maintaining my s-type
Old May 4, 2012 | 02:33 AM
Richard from Fraser Valley's Avatar
Default maintaining my s-type
my 2000 s-type 3.0 has 136000 Km on it what should I be doing in respect to preventive maintenance. Does the engine have a timing belt or chain what about a trany fluid change bleed brakes coolant etcetera any words of wisdom would be greatly appreciated
Thanks Richard
Old May 4, 2012 | 03:53 AM
JagV8's Avatar
Get a JTIS so you get all the info
Even has the maintenance intervals etc
Old May 4, 2012 | 05:00 AM
barney100golf's Avatar
try here http://jagrepair.com/images/AutoRepa...ype_jtp919.pdf
Old May 5, 2012 | 01:48 AM
I think I created a signature. Let know if it worked.
Thanks Richard
Old May 5, 2012 | 03:53 AM
JagV8's Avatar
Yep, it's good!
Old May 7, 2012 | 04:59 PM
So I guess that there is no timing belt?
Thanks Richard
Old May 7, 2012 | 06:44 PM
No belt, the cams are chain driven.
Old May 8, 2012 | 07:22 AM
The Chris X's Avatar
JTIS covers it, but it is worth emphasizing that if you still have the original brake fluid you are way overdue for a complete flush. At this point your fluid will have been aerated and likely have a good bit of water in the system, and the boiling point will be lower then spec. Easy DIY job - best of luck!
Old May 19, 2012 | 12:49 AM
Did a brake fluid flush went well it looks like it had its maintenance because the fluid came out looking good
Old May 19, 2012 | 09:40 AM
Mikey's Avatar
Richard- the physical appearance of brake fluid means very little. Good fluid can look blecch and vice versa.
Old May 19, 2012 | 12:18 PM
Thanks for advice. I pumped a full liter through the brake system so I think I'm good.
Thanks Richard
37driver
Oct 4, 2015 05:58 PM
Clare Jennings
Oct 4, 2015 05:43 PM
