Mass air Flow Connector Wiring Diagram
Old Aug 10, 2021 | 08:28 AM
Paulie710's Avatar
Default Mass air Flow Connector Wiring Diagram
Does anyone have a wiring diagram for the mass air flow connector.for an 07 s type 3.0
Old Aug 10, 2021 | 12:07 PM
kr98664's Avatar
Is this what you need? See figure 03.1, towards the upper right of the page:
http://www.jagrepair.com/images/Auto...cal-2006on.pdf
Old Aug 12, 2021 | 01:28 PM
Paulie710's Avatar
Default i have 2 wires that are green and white ugh!!!
i hav3
Old Aug 12, 2021 | 01:34 PM
Paulie710's Avatar
i found the diagram thanks.........but i noticed I have "2 green and white wires" why??? all the other colors seem to match up...someone did an engine job and repalced the maf connetor and all the wires recently can apart..........i actaully unplugged the maf sensor and car idles more smoothly and actaully runs much better,No b w what??
Old Aug 12, 2021 | 05:03 PM
JagV8's Avatar
Something's very wrong with the MAF or the air flow over it, then.
Old Aug 12, 2021 | 05:52 PM
Paulie710's Avatar
I just replaced the maf sensor same thing runs better when unplugged so what do I do now....still not sure about the wiring
Old Aug 13, 2021 | 02:25 AM
JagV8's Avatar
Could be a bad or wrong replacement, or done wrong.
They very rarely need changing, so why did you do it?
Which of P1000 / P1111 do you have?
Do you / did you have other codes / which ones?
You might OBD measure the MAF at idle and post it.
Old Aug 13, 2021 | 10:10 AM
Paulie710's Avatar
Thank you for your help the code I am still getting is P0103 And like I said earlier If I unplug it the car runs smoothly and idle smoothly Is still wondering why I have 2 green and white wires in the harness for the maf I would like to confirm that I have the wiring Right before moving on
Old Aug 13, 2021 | 03:46 PM
JagV8's Avatar
Sounds like you don't or it's the wrong part. Why are you changing it?
Old Aug 13, 2021 | 04:03 PM
Paulie710's Avatar
I am changing it because it keeps throwing the code Before I want to deem the replacement part bad again I want to make sure I have the wiring correct With that being Said Is is there anything else that would throw this code
Old Aug 13, 2021 | 05:14 PM
kr98664's Avatar
I am still getting is P0103...
A few random thoughts, offered for free and worth every penny:
Are you positive you're working on the correct sensor? Does it has 5 wires as shown on the wiring diagram?
When the sensor is disconnected, do you get any additional codes? (Don't be like me and just respond, "Yes", but rather tell us the codes...) This would help confirm you've working on the right sensor.
Where did you get the replacement sensor? OEM? No-name Chinese part on eBay? Some of the latter are notorious for poor quality, even when new.
Did you order the replacement by description (i.e. MAF sensor)? Or by the number on the part in front of you?
The wire colors not matching? This may not be a big deal. Jaguar may have made some minor changes to the harness, or used a different vendor. Minor changes like that don't always get well documented, especially near the end of a production run. (I worked in technical publishing for 5 years and can vouch for this.) The proof is how the wires are connected, so you'd have to check them back to specific pins on the ECM to be sure.
Some recent history of the car would help, too. Is this a derelict dragged from a field and you're trying to bring it back to life? Or did this belong to a retired electrical engineer and this was his baby until he passed away, and you bought this cream puff from his widow? Something in between?
When did the problem first occur? If the car had been driven some time with the existing wiring, and had no faults until just recently, you can at least be sure the wiring was connected correctly. There could be a new fault such as a broken wire or a short to ground, but it's not going to be a miswiring problem.
Is that enough questions for ya?
Old Aug 13, 2021 | 06:34 PM
Paulie710's Avatar
I'm sorry I have been a mechanic for the past 40 years I know what a mass air flow sensor looks like I also get a code P0102 when it when it is unplugged so obviously I am working on the right sensor I ordered an install the same sensor that has been in there for the past 5 years Reason I changed it is because It has an erratic idol is attic idle and it keeps throwing code P0103
Old Aug 14, 2021 | 03:00 AM
S-Type Owner's Avatar
Well, Paulie, you certainly get the "Run on Sentence of the Month Award" for that one.
You also have once again not managed to answer some of the questions put to you:
1. You ordered and install(ed) the same sensor; okay, was it original Jaguar, Denso, a reputable OEM like Delphi, or from the Sum Ting Wong parts factory in Shan Dung, China?
2. You have been asked if there are other codes present
3. You have been asked if all the emissions readiness flags have been set - "Which of P1000 / P1111 do you have?"
We respect that you have been a mechanic for a long time, but the above are legitimate questions and without answers, it is like you are expecting us to describe a full room via looking through a keyhole...
Old Aug 14, 2021 | 05:52 AM
JagV8's Avatar
From the jag doc (free download), there are multiple causes of P0102 / P0103. There are likely detailed pinpoint tests, too, if you look.
Old Aug 23, 2021 | 10:19 PM
Paulie710's Avatar
Where can I find jag doc
Old Aug 24, 2021 | 09:41 AM
JagV8's Avatar
Stickies
Old Aug 24, 2021 | 04:30 PM
Paulie710's Avatar
I have no idea what that means can I get a little more information
zray
Sep 29, 2018 07:03 AM
Paulie710
Jul 8, 2018 10:57 AM
rafasilva
Sep 13, 2017 12:26 PM
Davedavies
Jan 4, 2017 07:46 PM
Adam Lueb
Oct 29, 2010 10:04 PM
