Moonroof Won't Open
Old Feb 15, 2014 | 03:21 PM
OldMike's Avatar
Default Moonroof Won't Open
I'm at the limit of my knowledge on this one -- and it didn't take very long to get there!
I searched this forum for answers and didn't find anything. I looked in the JTIS and I get to the part that says "Go to the Jaguar approved diagnostic system." I have no idea what that means!
The moonroof is fully closed and won't budge when the switch it pushed or when the global opening function is used on the key fob. There is no sound such as a motor running and the fuse looks okay -- I didn't have another 20A fuse to replace it with, but it looks fine.
So, what's my next step?
Old Feb 15, 2014 | 07:21 PM
abonano's Avatar
Next step would be to ensure the sunroof motor harness is actually connected to the motor. If I recall, the motor should be in the vicinity above the console on the headliner that contains the moonroof switch and lights. Come to think of it that switch may not be connected either.
There also should be a relay for the moonroof / check JTIS.
Old Feb 15, 2014 | 08:47 PM
OldMike's Avatar
This is what JTIS says about the panel not opening...
Attached Thumbnails Moonroof Won't Open-screenshot2014-02-15at93845pm_zps049fe2a6.png
Old Feb 15, 2014 | 10:07 PM
cat_as_trophy's Avatar
Hi OldMike; and greetings from down under ...
I sense you are still wrestling with the "Jaguar Approved Diagnostic System". This is referring to the tools package (hardware and software) that unlike purely generic OBDII code scanners, is able to interrogate, reset and/or calibrate all peripheral control modules as well as the ECM. It is normally only available to Jaguar dealers or specialist independents ... although more and more forum members are experimenting with cheaper (read cloned) tools like Mangoose ... see plenty of threads here.
Of more immediate concern, as pointed out by abonano, the sunroof motor is controlled by "relay" ... and like many of these S-Type devices that look like relays, but often contain controllers and other electronics ... you may find that the power feed and the relay energising coil are each fed from different fuses. Sorry I haven't consulted wiring diagram for your year model - there are at least 4 different sets - and only that for my much later model falls to hand.
My point is ... check the appropriate wiring diagram carefully ... pull, test, swap each fuse that impacts on the motor circuit. Beware the trap of pronouncing a fuse "good" on the basis of looks ... test it. If you have no spares (?) then swap similar rated fuses with other circuits for test purposes. Take care before swapping "relays" unless you know the replacement is electronically identical. It may be that you have an issue with switches, connectors, wiring loom, or even in CANBUS ... but let's get the basics sorted first.
Best wishes for an early fix.
Ken
Old Feb 16, 2014 | 06:44 AM
OldMike's Avatar
The 2003 Electrical Guide shows the location of the relays, it doesn't mention any other locations for relays, so please let me know if the one that controls the sliding roof is in this photo or somewhere else. Thanks.
Attached Thumbnails Moonroof Won't Open-6449ae68e4b1a7a88794bbd0f89af09a_zps4ac14048.jpg
Old Feb 16, 2014 | 07:35 AM
clubairth1's Avatar
Community Influencer
Have you pulled the overhead console to check if power is getting to the motor or switch?
Old Feb 16, 2014 | 08:22 AM
JagV8's Avatar
I'd be worried that it may open and then refuse to close. Stuck closed is better, I think.
JLR Mongoose clones (with IDS/SDD) are about $45 now I think, if you want to try the OE tool.
Old Feb 16, 2014 | 08:39 AM
OldMike's Avatar
No, all I've done so far is what I mentioned in my first post. I guess I could try taking the console apart if that's the best next step.
Old Feb 16, 2014 | 08:43 AM
OldMike's Avatar
No, I haven't tried the clone -- I have a question or two, will I need a PC (Windows) computer to use it, and where is it available for $45 (I found one for double that). Thanks.
Old Feb 16, 2014 | 11:47 AM
police666's Avatar
Is the hidden manual winder like with most electric roofs in case of power / motor failure?
Usually some sort of Allen key type hole near the motor.
Old Feb 16, 2014 | 12:42 PM
JagV8's Avatar
Yes, Windows only - read the detailed thread (General Tech I think).
dsnyder586
Dec 29, 2024 07:39 PM
Dagny
Jun 11, 2024 01:06 PM
BadKat174
May 26, 2023 12:29 AM
findre
Sep 10, 2015 05:46 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
