more lowering spring dramas
Old Apr 9, 2011 | 08:22 PM
Joel's Avatar
Default more lowering spring dramas
I have found lowering springs on ebay that say - suit V6 s-type. would anyone know if they'l fit my V8? they are the only set that i can find in australia, so im not getting hammered with shipping costs, from the U.S they're nearly $1000. any help would be great thanks guys
Old Apr 10, 2011 | 05:44 AM
bfsgross's Avatar
Need brand and part # of springs.
Old Apr 11, 2011 | 03:06 AM
Joel's Avatar
They're EIBACH PRO-PACK brand, no model number available just says suit v6 s-type. seller wont respond...
Old Apr 11, 2011 | 05:47 AM
bfsgross's Avatar
My ride wears H&R Sport lowering springs. Have you considered these? They'll work on your car too.
Old Apr 11, 2011 | 08:32 AM
androulakis's Avatar
H&R & Eibach both spec different part #'s for the V6/V8 Naturally Aspirated cars and the STR. The spring rates are different due to the CATS struts v/s non CATS. I suspect the R springs are a higher spring rate and if installed on a NON R may cause it to ride like a mechanical bull.
Physically they will fit and bolt in just fine.
Just Fyi.
Take care,
George
Old Apr 12, 2011 | 03:36 AM
Joel's Avatar
ok, so i bought them, fingers crossed! thanks for your help, i will post pics when/if done.
Old Apr 12, 2011 | 07:45 AM
bfsgross's Avatar
Hi George, I believe Joel's 03 4.2 has the CATS suspension. Other than that you're likely correct regarding difference in spring rate. Joel, does your 4.2 have CATS?
Old Apr 28, 2011 | 10:09 PM
Blakeb1's Avatar
I have seen some generic versions avail
Old Apr 29, 2011 | 02:27 PM
Leedsman's Avatar
In UK, with all the speed bumps, no-one lowers their cars anymore! My Jag. has tough rubber ***** in the springs to actually RAISE the car just over an inch (fitted by me, not OEM...)
Leedsman.
Old Apr 29, 2011 | 05:29 PM
jag79's Avatar
Leedsman.
Innit mate! , When I looked at your location, it brought back long memories when I went to Leeds back in 00' The place is mostly a financial hub, but anyhow good old times I had there; getting into bar fights with soccer holigans and what not ... ,
Good thing you modded your jag's springs, the roads there were really horrible
danke
May 29, 2023 01:01 PM
ym37tech
Feb 8, 2016 01:04 PM
08Z06
Oct 24, 2015 05:46 PM
Harry Dredge
Oct 10, 2015 09:33 AM
1LowCat
Sep 14, 2015 07:51 PM
