My 2003 S-Type won't start
When I start the engine, it turns over just fine but then stops. I wait a few seconds and try it again but the same thing keeps happening. It has more than a half tank of gas and the battery is good.
Any idea why it fails?
CAN BUS is what I want to check as my symptoms perfectly matched what I read for the u0167 code. But I can't find anything on where it is or what it looks like. Anyone?
CAN BUS is what I want to check as my symptoms perfectly matched what I read for the u0167 code. But I can't find anything on where it is or what it looks like. Anyone? Or vcim connector.
Your resurrection of this ancient and unresolved thread makes the third on your no-start issue going back to mid January. As I recall the PATS issue was mentioned in at least one of your earlier threads as well... Did you check the PATS light for a flashing trouble code?
Ok tried reset procedure nothing happened. Took off manifold and fuel rail and no fuel at all.fuel comes out of filter when hose disconnected. Could the new crankshaft sensor bad a bad apple? Getting spark no fuel at fuel rail but when fuel pump is primed and filter hose disconnected it spits fuel. Should I revisit the purge valve?
katproffitt
Apr 15, 2021 09:53 AM
2003 S-Type
Jul 10, 2012 08:41 AM
jllantin
Jul 8, 2012 04:38 PM
Jan 19, 2007 02:39 PM
