My 2003 S-Type won't start
Old Jun 3, 2014 | 11:43 AM
1234jen's Avatar
Default My 2003 S-Type won't start
When I start the engine, it turns over just fine but then stops. I wait a few seconds and try it again but the same thing keeps happening. It has more than a half tank of gas and the battery is good.
Any idea why it fails?
Old Jun 3, 2014 | 11:59 AM
JagV8's Avatar
As you start & it turns over keep watching the PATS light - does it go out and stay out? If not, leave key in pos II and watch that light, counting flashes.
Old Mar 24, 2020 | 05:10 PM
Vandyone's Avatar
Default 08 CAN BUS location? S-type
CAN BUS is what I want to check as my symptoms perfectly matched what I read for the u0167 code. But I can't find anything on where it is or what it looks like. Anyone?
Old Mar 24, 2020 | 05:13 PM
Vandyone's Avatar
Default CAN BUS location? S-type 08
CAN BUS is what I want to check as my symptoms perfectly matched what I read for the u0167 code. But I can't find anything on where it is or what it looks like. Anyone? Or vcim connector.
Old Mar 24, 2020 | 09:38 PM
S-Type Owner's Avatar
Your resurrection of this ancient and unresolved thread makes the third on your no-start issue going back to mid January. As I recall the PATS issue was mentioned in at least one of your earlier threads as well... Did you check the PATS light for a flashing trouble code?
Old Apr 9, 2020 | 12:22 PM
Vandyone's Avatar
Pat's light doesn't show any codes but it won't kick over so idk if it is supposed to.
Old Apr 20, 2020 | 07:34 PM
Vandyone's Avatar
Default Update
Ok tried reset procedure nothing happened. Took off manifold and fuel rail and no fuel at all.fuel comes out of filter when hose disconnected. Could the new crankshaft sensor bad a bad apple? Getting spark no fuel at fuel rail but when fuel pump is primed and filter hose disconnected it spits fuel. Should I revisit the purge valve?
Old Apr 21, 2020 | 01:23 AM
JagV8's Avatar
You should have fuel in the rail.
Also, the OBD reading should look like you have.
If the OBD says you do but you haven't then the sensor may be bad.
Old Apr 22, 2020 | 09:14 PM
Vandyone's Avatar
Default Cheap sensor
Ok also it's the cheapest aftermarket one I could find. I right in thinking it needs to be an expensive sensor?
Old Apr 22, 2020 | 10:03 PM
car5car's Avatar
code reader with live data should show RPM if crank sensor is OK. If sensor is dead, no RPM when you try to start.
katproffitt
Apr 15, 2021 09:53 AM
locky995
Nov 9, 2018 04:42 PM
2003 S-Type
Jul 10, 2012 08:41 AM
jllantin
Jul 8, 2012 04:38 PM
Jan 19, 2007 02:39 PM
