My first oil change on the 4.2 S Type
Old Sep 9, 2015 | 05:50 PM
Gerard Radimaker's Avatar
Default My first oil change on the 4.2 S Type
Greetings!
Time for my first oil change on the 2005 S Type 4.2 84K and I want to service it myself. I read the threads and it does not seem to be a big deal but I question what type of oil to use. The manual says Castrol 5W30 is preferred with 0W30, 0W40 and 5W40 acceptable. The threads talked a lot about beef tallow and left me rather confused. Previous owner was using Motocraft synthetic blend 5W30 with oil changes at 5,000 miles. I have heard in the past that if you have been using a synthetic blend you should stick with it, any thoughts? Also the owners manual says 10K between oil changes. Is this pushing it a little? My previous Mercedes C280 Sport ran on European spec 0W40 and I changed the oil every 10K. When I sold it with 227K on it the engine was still running strong with no abnormal consumption. Seeing that the same engine was used in the Lincoln as the S Type I am wondering if Motocraft would be a good choice? Thanks in advance for any and all input.
Old Sep 9, 2015 | 06:34 PM
Mikey's Avatar
If I saw that I'd assumed I'd accidentally clicked on a cooking site. No idea what you might read. Beef tallow?
False, old wive's tale.
10K is quite conservative on modern cars. 15K is becoming the standard.
Use it if that brand pleases you. There is little or no difference from one brand to the next, essentially the car couldn't care less.
Pick the viscosity that best suits your climate and you'll be fine.
Old Sep 10, 2015 | 12:49 AM
JagV8's Avatar
10K will be fine.
Any oil that meets the min spec WSS-M2C913-B also fine, go with 5W30 if that's the right one for your region. Car really doesn't care whether fully synthetic or not.
Old Sep 10, 2015 | 02:17 PM
jkallinen's Avatar
I Used Castrol synthetic blend 5w30. Be prepared to have 7 quarts on hand and
watch the youtube video by Vance about pulling down your belly pan. Went to
change mine and no belly pan. Was surprised how much oil is in this engine.
Almost double my other V6 engines.
Old Sep 11, 2015 | 08:26 PM
jkallinen's Avatar
Old Sep 13, 2015 | 12:38 AM
SoCalJagS's Avatar
Use Mobil 5-30 extended performance full synthetic, use a WIX brand oil filter, one of the best. I change every 3000 miles, or at least once a year, which ever comes first. I know they say you only have to change oil every 7000 - 10000 miles, but oil is cheap insurance.
Old Sep 13, 2015 | 09:28 AM
JagV8's Avatar
It's 10,000 miles or every 12 months whichever is sooner so you look good to go.
Old Sep 13, 2015 | 09:38 AM
Beef dripping makes the best chips, but I'd avoid it in engine oil.
Old Sep 13, 2015 | 10:33 AM
Mikey's Avatar
Neither using synthetic oil nor changing it more frequently than OEM spec has proven to have had much effect one way or another, so it's money wasted other than making the owner feel better.
FabCat
Canada
Aug 20, 2023 10:11 AM
JaguarXKR
Sep 6, 2015 11:47 AM
niner nellie
Sep 1, 2015 10:53 PM
DeaconHull
Aug 31, 2015 10:09 PM
TC Johnson
Aug 29, 2015 08:55 PM
