Need another key fob for my 06str
Old Oct 11, 2019 | 09:32 PM
Aarcuda's Avatar
Default Need another key fob for my 06str
So where do I get one thatll work. That I can program with SDD?
my car only had one fob and I could use a spare or 2. Can I program a new one and still use my original or do I need to get all new ones and reprogram all at the same time?
and who cuts these weird keys?
Old Oct 11, 2019 | 11:02 PM
scottjh9's Avatar
The key is called tibbe i think....dealer for sure, but ask locksmith about tibbe....do not buy chinese knock off fobs ..will not program...get good used genuine jaguar fobs from the bay....just make sure they are 433mhz....match the fcc id numbers ....sdd will program fobs and keys easily ....been in your same situation with fobs and also programmed my 2 valet keys....sdd walks you through it with no guesswork.....most fobs from a US seller should work.....euro is different mhz.....you can buy the blank tibbes on the bay also ....the transponder is located in the key half of the fob if you want to buy that seperately to go with a used remote bottom half....pretty sure sdd allows up to 4 fobs and 4 keys, new or used....all have to be present when programming....sdd wipes them all clear then programs over again
Old Oct 12, 2019 | 07:01 AM
dopey's Avatar
As a general rule, North American models use 315MHz for their fobs, UK and Australia use 433MHz. If you are unsure then your best bet is to get a cheap Chinese fob, they have the ability to change frequency unlike genuine remotes which does NOT have this option.
https://www.jaguarforums.com/forum/s...6/#post1818790
Old Oct 12, 2019 | 09:11 AM
Aarcuda's Avatar
Thanks guys. That helps!
Old Oct 12, 2019 | 10:20 AM
scottjh9's Avatar
Sorry....bad info from me....you are correct about the mhz....wow that would have been a disaster....just plain missed it ..thanks for the correction...best match is by fcc id number or gizmo dopey posted
Old Oct 12, 2019 | 12:27 PM
Aarcuda's Avatar
Hey it happens! But I didnt buy any yet so we are still good! And now that ive solved my intake leak, I can concentrate on other stuff! Now!
thanks guys!!
gdrag
Apr 3, 2023 07:17 PM
ant17
Oct 15, 2022 06:06 PM
Lenny B
May 1, 2017 12:16 PM
Etobicoke sportwagon
Feb 23, 2016 03:24 PM
Burnham
Nov 9, 2015 03:02 PM
