Need help on 2005 S V8 4.2
Old Dec 29, 2011 | 01:06 PM
fatty's Avatar
Default Need help on 2005 S V8 4.2
I'm trying to buy a 2005 S v8 model.
Is there any well known problems to watch out before I made purchase one?
Old Dec 29, 2011 | 06:38 PM
bfsgross's Avatar
Only problem with the car was not enough folks bought em. Otherwise, very well laid out and built car. The 4.2 is venerable, belts out 300 hp with 310 lb/ft of ***** behind it. The ZF 6 speed trans. is strong, reliable, and shifts smooth as silk. I can guide you in squeezing out an additional 25 more hp from this motor. Have you looked into the 400 hp s/c STR?
Old Dec 30, 2011 | 02:42 AM
JagV8's Avatar
^ what he said
I think they get about 1 mpg less than the 3.0 but have so much more power available. Very smooth low-revving engine. I don't know of any special problems to worry about.
Old Jan 9, 2012 | 02:04 PM
Genesis1's Avatar
I njust got an 05 S 4.2. Absolutly love this car. Ill be doing some modes, most likely exahust and intak. Where would I look for a fuel management system? Tuner or programer??
Old Jan 9, 2012 | 04:04 PM
Bacardi 151's Avatar
I strongly recommend looking into a S-Type R (commonly referred to on here as the STR)...There's an 03 for sale on this board for $10500. 2005s with Navigation can be had for about $15K.
With any S-Type...
Check for coolant leaks
Check that the heat is hot and the A/C is cold
Check for inner tire wear (Jag updated the alignment specs due to excessive inner tire wear, an alignment is one of the first things you'll going to want to do when you buy the car)
Ensure the above the window trim is secure and not popping off
All the above aren't generally majorly expensive fixes, but are common problems that should reduce the sales price if a problem is found...
Old Jan 10, 2012 | 07:47 AM
JagV8's Avatar
Same as for the STR, maybe.
Neither are realistically available or going to do anything useful. It's a really nice 300HP car with a pretty high compression ratio (*) and lots of torque.
(*) higher than the STR
If you want to spend LOTS of money to attempt it, first buy a different car. May not be what you want to hear, but there it is.
Old Jan 10, 2012 | 08:41 AM
Genesis1's Avatar
My motto has always been "dont let common sense or money stop you" lol.
I dont understand why you would say that cleaning up the airflow in and out wont do "anything usefull" Ive yet to see any stock system that can compare to a well engeneered intake and exhaust. Im not expecting more HP nescessarily, just improve the overall efficiency...and sound.
On average even just replacing the stock or recomended air cleaner with something like the K&N high flow makes some improvement.
And I certainly agree with you, it is a nice 300 hp car...I love it and have only had it for 4 days!!
Now where did I put that twin turbo set up I had for the Caddy.....
Old Jan 10, 2012 | 09:47 AM
bfsgross's Avatar
Genesis, you want 20 extra ponies plus a sweet sounding exhaust? Place a K&N flat panel a/f in the stock air box, Eurotoys low temp. thermostat, fabricate a freerer flowing air intake tube, pair Magnaflow hi-flow cats, replace the stock center resonator with a Magnaflow dual inlet/outlet muffler, retain stock pipe over the axle, dump it all out of a pair of Borla's. Maintain 2.25" diameter pipe and inlet/outlets. Perform a hard re-set of the ECU.
Old Jan 10, 2012 | 09:52 AM
JagV8's Avatar
Dyno before and after and don't be surprised at the tiny difference....
Old Jan 10, 2012 | 11:58 AM
Genesis1's Avatar
Thanks bfs, and JagV8 does have a point, there wount be much of a gain at the wheels...but it will certainly have a much deeper sound.
Old Jan 10, 2012 | 03:50 PM
bfsgross's Avatar
Jagv8 may be correct, but you'll still have to dyno to prove me wrong.
Old Jan 10, 2012 | 04:41 PM
Could be a 50hp gain, if your OEM cat(s) are clogged...
Old Jan 10, 2012 | 08:09 PM
bfsgross's Avatar
Ditto. Bacardi and I can attest to being robbed by cats.
Old Jan 10, 2012 | 08:23 PM
Mikey's Avatar
Ya, I hate that kind of stuff
Old Jan 11, 2012 | 06:06 AM
bfsgross's Avatar
LOL! Good find Mikey.
KarimPA
Sep 27, 2015 08:46 AM
tassiejag
Sep 24, 2015 08:43 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
