NEED HELP
Old Sep 7, 2022 | 09:58 AM
Dwayne Mason's Avatar
Default NEED HELP
Is anyone familiar with this code P050B
it constantly keeps popping up on my 2007 Jaguar S-Type R.
what does cold start ignition timing performance mean? Any further explanation would be greatly appreciated.
Old Sep 8, 2022 | 02:50 AM
JagV8's Avatar
It's a generic OBD code so web searches will find it but you can also have a look for
JAGUAR ON-BOARD DIAGNOSTICS V8 Engine Management
maybe add such as P050B and/or PDF
Steve M's Avatar
Try this.
P050B Code: Causes, Symptoms, and How to Repair It! » (way.com)
Old Sep 8, 2022 | 03:03 AM
Joedotcom's Avatar
Hi
Just check the s-type drc and that code dont exist
you would be better finding some with Jaguar IDS/SDD to get accurate codes and to give you accurate causes
even buying a Icarsoft LR V3, which is the best out there for our cars, apart from Jaguar IDS/SDD, but icarsoft lr v3 will talk to most of the modules on the car
unlike cheaps ones which only talk to engine ecu and give generic useless codes
also if your in the AA get them out and get them plug in for free
cheers
Joe
Old Sep 8, 2022 | 05:42 AM
JagV8's Avatar
Originally Posted by Joedotcom
Hi
You must be using an out of date list of codes.
I posted how to find info.
Old Sep 8, 2022 | 12:16 PM
kr98664's Avatar
Are you seeing any symptoms with this code? Check engine light? Rough idle? Restricted performance message?
Or does this one simply show up any time you run a scan for codes?
If no other associated faults or indications, it might a case of your scanner not playing nicely with your car. In other words, it could be a nuisance message that doesn’t really mean anything.
Old Sep 9, 2022 | 12:33 PM
JagV8's Avatar
What???? That is VERY VERY unlikely.
Please let's treat it as we would any other code - there for a reason (possibly more than one reason).
Old Sep 15, 2022 | 08:54 AM
M-e-l-l-o-w's Avatar
I would also recommend using the jaguar SDD software and dedicated interface to find this fault.
Mellow
Darve62
Feb 6, 2021 12:55 AM
daro31
Feb 17, 2017 05:10 AM
flash88
US Southwest
Jan 27, 2017 04:56 PM
STR
17
Dec 14, 2010 04:59 AM
89jaguarvandenplaz
Sep 27, 2009 08:35 PM
