Need help identifying these wheels
These wheels are OEM Jaguar wheels right out of the box in MINT condition. The person tells me they are for a X-Type but I have yet to find one with these wheels on.
I think they may be for an S-Type, but would fit anyway. They are 17x7.5 if I did the measuring correctly.
Take a look and let me know what yr/model they came off of. There is a stamp on the inside of all the wheels that say they were made in July of 2004, with Made in Italy stamped on the inside hub of the rims too.
Probably from a later model like 03 or 04 17" were an option wheel I think 16" was standard.at least in 01 it was
The guy I got them from said he work at a Jaguar dealer here in NYC. And the wheels are OEM Jaguar wheels for an X-Type but I never have seen them on an X before. Which made me believe they are from a S-Type..
I couldnt pass up the deal, they are in 100% mint condition, out of the box and I paid $200 for the set.. I just need new tires for the wheels. (My current ones are worn so it works out perfectly)
Still maybe someone else could chime in and give some info..
Those were available on the 05 (and up?)X Type...
The wheel name in Andros...
here is the quickest link to them I could find....
http://www.jaguar.com.au/au/en/x-typ...ries/style.htm
They are 17"
They are 17"
They are 17"
They are 17"
Very strange..
So, did another look. They actually look very much like the Helios wheel. It is a 10 spoke but is a 16" wheel.
How did you measure your wheels? Mine are 17" Kronos and when I measure the outside lip it measures 18.5".
Here is a link to a 2004 accessory catalog for all models. The Helios wheel is in there.
http://www.jag-lovers.org/brochures/...cessories.html
Hopefully tomorrow I will pull one of my wheels off and make sure these bolt up like the person I bought them from said they would. And then I will get new tires/alignment and its perfect..
From an earlier post it sounds like you're measuring them as too large and they are probably 16". Have you read up on how to measure wheels? That must be on the net somewhere! There are other things to measure, too, before trying to fit them so be sure to find out what they are and how to check.
aholbro1
Dec 29, 2024 06:46 PM
trosty
26
Dec 18, 2022 06:40 PM
