No Communication with TCM
Old Nov 19, 2024 | 03:34 PM
Jag_Willi's Avatar
Default No Communication with TCM
Hallo,
I want to reset the gearbox control (ZF 6HP26) on my 3.0L S-Type, built in 2003, Mod.2002.5. WDS and IDS report "no communication with TCM". Technically, the control unit works. It switches up and down, everything is OK. That shows that the communication between the ECU and TCM is working, but not via the OBD port (OBD Port is definitely OK). The connector on the gearbox has been checked. Everything is OK.
What can I test? Are there ways to measure certain cables?
Regards, Willi
Old Nov 19, 2024 | 09:17 PM
scottjh9's Avatar
You can do a canbus test at the obd2 socket using a multimeter. You can also check voltage and grounds at the connector. When i did it i googled canbus check at obd connector using multimeter. There are a few really good walk thrus on it
Old Nov 20, 2024 | 10:40 AM
BigCatXJS's Avatar
Be aware that some clone cables do not support the full functionality of IDS. You need the Mongoose PRO cable. Apologies if you already have this.
Old Nov 20, 2024 | 10:49 AM
motorcarman's Avatar
Info I got a few decades ago.
File Type: pdf
Old Nov 20, 2024 | 12:20 PM
Jag_Willi's Avatar
Hello,
I'm going to measure the OBD socket again. Although everything else can be done via WDS. I actually only have a clone cable for IDS, which is only intended for use on the go or for reading. There's a WDS in the garage.
I wanted ideas like: measure cable X to Y. That's the cable from device X to Z. Unfortunately, I can hardly read circuit diagrams, or I don't understand the different networks, so I don't know which cables go from the OBD connector to the TCM.
I would be very grateful for help.
Best wishes, Willi
Old Nov 20, 2024 | 02:41 PM
JagV8's Avatar
The TCM is on the CAN bus, which is pins 6 & 14 of the DLC (the OBD socket).
ericnunez
Jan 20, 2024 09:12 PM
nersveen
Apr 17, 2020 04:14 AM
dma47940
Apr 15, 2019 06:30 PM
rd350ypvs
Dec 9, 2014 05:50 AM
nebelfuerst
Jun 30, 2013 02:46 PM
