Noise from the flywheel area
Old Aug 14, 2019 | 09:40 AM
Jjjon's Avatar
Default Noise from the flywheel area
Hey, car is -00 S-Type 4.0 v8. It makes strange sound when accelerating, its like something is loose. Sound appears only when in gear and accelerating,
as soon as i lift my foot off the throttle, sound stops. Mechanic tried to check where the sound comes from, and told me its coming under the flywheel.
He told me i have nothing to worry about, there´s just a little rock or something making that noise. Car drives good and smooth, transmission is working
nicely, but really could that noise be something i should not worry about? No fault codes at OBD test.
Old Aug 14, 2019 | 06:14 PM
abonano's Avatar
Check to make sure starter gear is not hitting the flywheel while engine is running.
Old Aug 14, 2019 | 06:29 PM
scottjh9's Avatar
could be a bolt comimg loose...I would check further
Old Aug 14, 2019 | 11:23 PM
Datsports's Avatar
also check the engine mounts.
Old Aug 15, 2019 | 10:18 AM
kr98664's Avatar
Check the torque on the starter mount bolts.
Old Aug 15, 2019 | 10:27 AM
scottjh9's Avatar
If a torque converter to flywheel bolt is loose or missing the noise will get louder as engine speed and load increases.....been there
Jose Arellano
Oct 31, 2017 07:12 AM
Jagstefano
Jun 24, 2017 11:58 AM
AfricanJag
Feb 18, 2015 01:30 AM
reedreed
Aug 27, 2014 05:05 PM
Diamondrmp
Aug 26, 2013 12:45 PM
