OK, this isn't good.
Old Feb 28, 2013 | 06:52 AM
chazaroo's Avatar
Default OK, this isn't good.
I was reading the manual for our 06 S-Type and found out that when you change the battery, you have to, among other things the radio will not work until the security code is re-entered. We don't have that code. Now what?
Old Feb 28, 2013 | 06:56 AM
jimbov8's Avatar
Phone your local jag dealer with the VIN number and proof of ownership and they should get you the code. As long as the radio is as fitted it should work, but don't forget to write the code down and keep it safe.
Old Feb 28, 2013 | 07:11 AM
Jon89's Avatar
Having to enter the radio code after replacing the battery is overwhelmingly a non-US thing. The vast majority of owners here in the US do not have to do so. Having said that, it would still be a good idea to obtain your car's radio code and have it available when you do indeed replace your battery just in case....
Old Feb 28, 2013 | 07:12 AM
JagV8's Avatar
The USA setting usually doesn't ask for the code.
Also, depending on model there's a bypass.
Old Feb 28, 2013 | 07:19 AM
joycesjag's Avatar
After a battery change in the US there are a couple of minor things that will be needed to be reset, EPB, windows, clock.
As mentioned no radio codes in the USA.
Old Feb 28, 2013 | 07:37 AM
chazaroo's Avatar
Thanks everybody. It's a relief to know it shouldn't need a code. I will however call the dealer to get it just in case.
Old Feb 28, 2013 | 09:54 AM
bfsgross's Avatar
Often times a new battery swap won't affect the radio security feature. If it does, simply push 1,2,3,4 on the radios phone feature.
Old Feb 28, 2013 | 12:21 PM
chazaroo's Avatar
So hit the phone mode button, then 1234?
Old Feb 28, 2013 | 01:47 PM
JagV8's Avatar
Is it asking for a code?
Old Mar 1, 2013 | 06:52 AM
chazaroo's Avatar
Won't know until tomorrow, when I change the battery.
Old Mar 1, 2013 | 07:12 AM
bfsgross's Avatar
The security system will only ask for the radio code if the battery is disconnected for a prolonged period of time. You won't have a problem by simply swapping in a new battery. If the radio dispay asks for a code, simply push 1,2,3,4.
Old Mar 1, 2013 | 08:48 AM
chazaroo's Avatar
Great. Thanks everybody.
Old Mar 1, 2013 | 09:58 AM
Gus's Avatar
Gus
Most good battery shops will back feed your system with a temporary power supply prior to removing and replacing your battery. This is to prevent any inconvenience a battery exchange could cause and this includes reprogramming. Ask them if they have that service.
Old Mar 1, 2013 | 11:21 AM
bfsgross's Avatar
Great advice Gus.
Old Mar 1, 2013 | 11:55 AM
shejag's Avatar
Hi
We use this code in the UK
Try the following holding down >>,AMEM and PTY press all 3 three at the same time.
Old Mar 1, 2013 | 01:51 PM
bfsgross's Avatar
Default ?
Originally Posted by shejag
Hi
Did you mean press and hold down: >>, AM/FM and PTY at the same time?
Old Mar 2, 2013 | 06:28 AM
shejag's Avatar
HI
Try >>, A.MEM, PTY
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
baskervillema
Oct 1, 2015 06:43 PM
black5litre
Sep 27, 2015 03:10 PM
