P0328 Knock Sensor replacement questions:
Old Jan 7, 2025 | 08:46 AM
mikesbaron's Avatar
Default P0328 Knock Sensor replacement questions:
2003 V8 Base.
Recent "Restricted Performance" flashing up on my dash and a code read show P0328, 1 CIRCUIT HIGH BANK 1. I just need some confirmation on replacement.
1. That this is the passenger side?
2. How difficult and what's the procedure for this replacement? The intake needs to come off I'm guessing?
3. Which sensor to purchase? Autozone and Rock Auto have so many options I don't know where to go.
Duralast Ignition Knock (Detonation) Sensor SU7012
Santech Ignition Knock (Detonation) Sensor KS0057
Duralast Ignition Knock (Detonation) Sensor SU7013
Santech Ignition Knock (Detonation) Sensor KS0108
NTK Ignition Knock (Detonation) Sensor ID0269
NTK 72887- ID0269 Knock Sensor
Standard Ignition 2 Terminal Knock (Detonation) Sensor - KS305
Import Direct Ignition 2 Terminal Knock (Detonation) Sensor - 17-0903
Import Direct Ignition 2 Terminal Knock (Detonation) Sensor - 17-0902
Old Jan 8, 2025 | 10:36 AM
kr98664's Avatar
The service (aka workshop) manual is available near the bottom of this page:
JagRepair.com - Jaguar Repair Information Resource
It's a huge PDF. (The manual covers all models, so make sure to look in the section for the V8.) Scroll down to page 1980 of the PDF for pinpoint tests for code P0328.
If you need to change the sensor, see pages 790 and 1082. Code P0328 is applicable to the RH sensor, which is on the US passenger's side. The two sensors are located on top of the block, inboard of the heads, hidden under the intake manifold. The following picture, shameless stolen from eBay, shows the two sensors on each side in the middle:
More pics of the same engine here:
https://www.ebay.com/itm/235869702894
Old Jan 8, 2025 | 01:25 PM
mikesbaron's Avatar
TY sir! Very helpful.
Old Jan 8, 2025 | 02:26 PM
motorcarman's Avatar
Do not forget to replace the EGR cooler hose.
Old Jan 8, 2025 | 03:43 PM
mikesbaron's Avatar
What goes on with the EGR cooler hose, other than getting old and cracking? Is there another name and/or oem part number for it? i'm not finding EGR cooler hose in the online microfiche search.
https://www.jaguarparts.com/search?s...log_type=parts
Old Jan 8, 2025 | 06:50 PM
Actually the return hose under the SC connects to the throttle after the hoses that go to the EGR pass the coolant on it's way back to the water pump so look for the THROTTLE BODY RETURN HOSE/4.2 LITER SUPERCHARGED/THROTTLE/FROM VIN (N13089) AJ89746
It is a rubber hose and it's location makes it difficult to replace.
Change it while you are there!!!!!!!!!!!!!
(sorry I called it the EGR hose when the EGR is only one of the components to use this in the return path)
Old Jan 9, 2025 | 01:59 AM
JagV8's Avatar
It may be AJ89746 aka AJ8 9746
Throttle Body Coolant Return Hose aka Valley Coolant Hose
Look for the full part # above on this site as there's a full list of related parts and I think pictures
Old Jan 9, 2025 | 09:03 AM
mikesbaron's Avatar
If I have non SC engine would I have this hose? I'm not finding part number when I search my normally aspirated V8 engine.
Search says it doesn't fit my engine.
Home 2003 Jaguar S-Type AJ89746
Jaguar logoNo image available
Engine Coolant Hose - Jaguar (AJ89746)
2003-2009 Jaguar
  • Sale Price:$25.79
Jaguar Parts
This part does not fit your 2003 Jaguar S-TypeChange vehicleAdd to Cart
Old Jan 9, 2025 | 09:22 AM
You list a 2006 S-Type R in your signature!!!!!!!!!!!!!!!!!!!!!
Old Jan 9, 2025 | 09:59 AM
mikesbaron's Avatar
Didn't realize that was on my signature (it's my old car). But I DID post my current car at the top of my original post!
Old Jan 9, 2025 | 10:05 AM
clubairth1's Avatar
Community Influencer
With the NA engine it will be far less work to remove the intake manifold to get to the knock sensors. The NA engine also has a coolant hose under there so I would be planning on changing that. I would also replace both knock sensors since it is a bit of work to get to them and you will have everything apart anyway.
You list all after market knock sensors and that's up to you but I would search out the Jaguar OEM parts.
Old Jan 9, 2025 | 11:20 AM
mikesbaron's Avatar
Thank you.
Does this look like the coolant hose my NA needs?
https://www.jagbits.com/product/AJ88514.html
Old Jan 9, 2025 | 12:46 PM
clubairth1's Avatar
They differ depending on your VIN? Can you post the last 6 digits?
Here is a kinda close thread with some pictures.
4.2 NA Intake Removal
Old Jan 9, 2025 | 12:50 PM
mikesbaron's Avatar
M51 493
tjankovs
Nov 22, 2025 01:39 AM
Flappers
20
Aug 5, 2023 06:54 AM
fourkegdave
Aug 17, 2022 09:56 AM
Carnival Kid
Apr 1, 2018 12:39 PM
wordman
Feb 1, 2013 11:12 AM
