Power Steering shudder
Old May 25, 2010 | 11:38 PM
Oldengineer's Avatar
Default Power Steering shudder
I've noticed the last couple of days that, if I turn my steering wheel with the car sitting still, I can feel a shudder through the steering wheel. Anybody else run into this??
Regards:
Oldengineer
06 S-Type VDP
Old May 26, 2010 | 01:04 AM
JagV8's Avatar
How far do you need to turn it to cause that?
Could it just be normal for the PAS?
(I was very tempted by the "well, don't do that" joke.)
Old May 26, 2010 | 06:50 AM
joycesjag's Avatar
Engineer there was some talk about an additive that goes in the power steering reservoir that Jag has. It does away with the shudder, cooing, and "column noise". I will look for that thread.
Found it:
https://www.jaguarforums.com/forum/s...steering+noise
Old May 26, 2010 | 12:25 PM
GaryinOregon's Avatar
My 03 stype has the 'shutter' as well. I had the Jag Shop in Portland, Oregon do the steering additive a month ago and it completely got rid of the annoying noise but the hudder remains. Asked the technician and he said, it's annoying, but the additive will not address the shudder. The bushings would need replacement, if you want that totally removed. I asked if it was safe to drive and he said, sure, no problem, but it is somewhat annoying. It only does it when I turn the wheel to the far right or left quickly.
Old May 26, 2010 | 12:29 PM
tbird6's Avatar
Oldengineer;
Your car is a 2006 and should not be having this issue?? I have attached several TSB's concerning steering noise. I also agree to try the additive first. It's cheap and easy with no downside. The part number is in one of the attached TSB's.
File Type: pdf
File Type: pdf
File Type: pdf
Old May 26, 2010 | 09:04 PM
pdr1966's Avatar
Default I'll join the post
Mine does this, kind of feels like a chuckle/kicking back when you turn it quickly.
I have not looked into it, but will follow the post and look at it more when I have time to.
Pete
Old May 26, 2010 | 11:22 PM
Default Thanks for your help.
First chance I get, I'll pick up a bottle of the additive at the dealer and give it a try.
Regards:
Oldengineer
Old Apr 28, 2011 | 12:35 PM
amcdonal86's Avatar
Did you ever solve this?
Old Apr 28, 2011 | 12:41 PM
joycesjag's Avatar
yeah he sold his car!!!!!
No really, oldengineer has sold his vehicle and only pops in from time to time nowadays. I believe that the additive did fix his problems as I recall.
Old Apr 28, 2011 | 12:45 PM
amcdonal86's Avatar
Dang, I've already put the additive in, and then when my squeaking noise didn't go away, I added some Lucas Oil stop leak power steering additive (DB6's suggestion). That stopped the noise, but now I have the shudder! I think I'd rather have my noise back!
Old Jun 1, 2011 | 02:35 PM
amcdonal86's Avatar
Well, the stutter/shudder/chuckle is still here! I am at wits end!
I will probably get another jar of that additive stuff.
Old Jun 1, 2011 | 03:01 PM
JagV8's Avatar
You're not supposed to use more additive. You sound to have a different problem so should look for what it is. Which S-Type do you have?
Old Jul 12, 2011 | 11:17 AM
rkh3's Avatar
Default Steering Shudder
So, have the same shudder symptoms. My mechanic diagnosed as a system leak akin to a fluid leak except the leak sucks air in to the system. A new rack and steering box installed right around $2K and still have the shudder. Talked to the dealer and they said all the lines should be replaced. I f that doesn't do it then the reservoir would be next. Really? I'm not sure my warranty company or my funding resources are able to do the "keep throwing parts in til it's fixed" approach. Any thoughts?
Bcrary3
Sep 26, 2015 10:36 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
