Problem with jaguar s-type v6 Transmission
Old Nov 20, 2015 | 12:58 PM
C.A's Avatar
C.A
Unhappy Problem with jaguar s-type v6 Transmission
hello all
i'm new in this best forum , and i have a problem with my jaguar s-type v6 Transmission .
my gearbox is work with ( D ) and my car have move, but when i change to ( R ) my car is not move to back !
please people help me and answer me with solution as soon as possible .
Old Nov 20, 2015 | 02:16 PM
JagV8's Avatar
More details of your car needed, so we can figure the actual trans as they suffer from different problems.
Before or after VIN M45254? Or, what is biggest number on the J-gate?
Old Nov 21, 2015 | 11:52 PM
C.A's Avatar
C.A
Hello sir
where i will found this vin ?
My car is jaguar s-type
30 v6
2001 / 2002
Old Nov 21, 2015 | 11:58 PM
C.A's Avatar
C.A
Hello sir
i'm so sorry i have this information about my car and real information , some body show my the vin
have a nice day
Old Nov 22, 2015 | 04:30 AM
Firstly welcome.
Your car is an early version, known as an X200, and has the Ford 5R55N transmission fitted.
These units had issues, mainly from contaminated fluid, due to the STUPID sealed for life tag attached.
The fluid needs changing every 80000kms or so, or 5 years if the car is used little.
Wear in the bore of the servo pistons also caused issues.
I would suggest changing the fluid, simply drop it out, and refill with fresh fluid. I did a write up on this a while ago, and it is in the "stickies" at the top of this section.
When the old fluid is drained, inspect it for metal "bits", and if that is found the transmission needs rebuilding. Being a Ford transmission, the $$ will not be too bad, even in Tripoly.
The gear select cable is known to stretch, and even slip out of the crimped end ferrules. There is a TSB in the same top section about this.
Old Nov 22, 2015 | 09:49 AM
JagV8's Avatar
They do quite often suffer a stretched shifter cable. Might adjust but otherwise replace.
Old Nov 22, 2015 | 11:39 PM
C.A's Avatar
C.A
Grant Francis
thank u very very much but i have change oil of gearbox and i have a same problem !
but some body say i can change my gear box with another one for Ford 5R55N .. Is this Right ?!
Old Nov 22, 2015 | 11:43 PM
C.A's Avatar
C.A
JagV8
thank u too and i will tray to change the shifter cable .
Old Nov 22, 2015 | 11:58 PM
It is a "Ford Family" of transmission.
I dont know of Fords that run that transmission. The Explorer ran the 5R55E, and NOTHING from each unit fits the other.
You would need to find a 5R55N unit, and then a s/hand may be as bad as the one you got.
Not sure of transmission repair places where you call home, but down here there are plenty, and this "Ford" trans is cheap to overhaul. including all the updated bits.
That is the path I will take if either of my 2 need it.
That select cable would be a smart idea, and if it makes NO change, at least you now have the "updated" select cable.
Old Nov 23, 2015 | 12:22 AM
C.A's Avatar
C.A
Grant Francis
thanks again and i hope god help me about my gearbox and i will INSHAA ALLAH chick the cable or change it as soon as possible .
Have a nice day and i will come back again to give u what's new !
Old Dec 20, 2015 | 01:55 AM
C.A's Avatar
C.A
hello again
i have tray every thing Grant Francis but without any solution please do u have another solution for my gear box ?
NOTE : when i do gear box on ( D ) the car is slowly but when i d on ( 4 ) MY CAR IS VERY VERY GOOD BUR ( R ) IS NOT WORK YET ..!
Old Dec 20, 2015 | 04:04 AM
Bugga.
OK, dirty hands time.
Drain that fluid, the drain plug is on the LH front lower corner of the pan.
Measure what came out, it should be AROUND (approximately in some languages) 5litres.
Inspect that old fluid for "gunk", as in metal bits.
If that old fluid is BLACK like old engine oil, you got problems.
Decission time is now here based on what you find.
1) Dirty/grubby oil:
Refill with 5litres of fresh fluid, drive it about 25kms, drop it again, and refill it again, do the same after about 100kms, and IF the trans appears to be getting "better", keep doing this drop and refill until what comes out is about the same colour as the stuff going in. THEN drop the pan and replace the filter and its o/rings, and refill it again.
IF after 2 drop and refills there is NO change to the transmissions behaviour, stop wasting money and go onto step #2 below.
Do this filter again after about 80K to 100K kms, and enjoy the car.
2) Metal/stuff in the muck you drained out:
Remove the transmission and get it rebuilt and updated.
There is NO "quickie" fix for it IF it has gone that far, and is a reflection of previous lousy maintenence.
Both of mine had very grubby fluid, and now after 8 drop and refills, using Full Synthetic Fluid, they are as SMOOTH as I would ask of any transmission, BUT, their behaviour when we first got them was sad indeed, such as unwilling to change down, shuddering on upshift, etc.
My "magic wand" is fresh out of poewer with this transmission. I hope the fluid refresh works.
Automatic transmissions are all smoke and mirrors to me, apart from the basic fluid/filter bit, and the knowledge that the fluid MUST be maintained as fresh. The only auto trans I have ever rebuilt was in 1969 when my brothers Dodge PowerFlite 2 speed became a 1 speed, and that scared me off working on them for life.
NOTE:
The fill plug is on the rear of the transmission on the RH side, up high on the rear face, facing the rear of the car, and is 10mm hex key plug. You will NOT see it (unless on a hoist), but if you feel around up there you easily feel it.
Klriess
Feb 24, 2022 01:21 PM
GoodWins62
Nov 17, 2015 12:43 AM
BKSinAZ
Nov 2, 2015 08:51 AM
dollison
Oct 24, 2015 04:21 PM
StephenB
22
Apr 1, 2013 10:43 AM
