Rattling sound during idle around flywheel area
Old Jan 16, 2013 | 05:39 PM
ddyke2000's Avatar
Default Rattling sound during idle around flywheel area
I have a 2000 s type 4.0 I just recently purchased. I noticed that during idle it sounds like the flywheel is rubbing something. When I rev it to higher rpms the sound goes away. I also noticed that through the opening the fly wheel looks a little rusted due to it sitting before I bought it. I have put about 1500 miles on it and the sound hasn't gotten better or worse. Could it be the torque converter if its just idling or is there something else? Also is it a sealed transmission because I can't check the tranny fluid to see if it has enough. I don't want to have to move the tranny off if I don't have too. Please help oink me in the right direction.
Old Jan 16, 2013 | 05:48 PM
tbird6's Avatar
Just be very careful here!!!
If you don't know Jaguars you have a car that needs the timing chain tensioners replaced. If not they will fail and destroy the engine. I have never heard of the problem you describe.
So do you know if they have been changed? The sound you describe could be the ratting of the timing chains because they are loose. When you rev the motor the noise does not go away but you can't hear it over all the other noises.
After you figure this out then yes. I would do a transmission full service. Drop pan, change filter and fluid. Don't let anyone charge you a lot for this as the car has a Ford 5 speed automatic which has been installed in millions of Fords. Dead common unit.
Old Jan 16, 2013 | 06:30 PM
police666's Avatar
i had a loose heatsheild on a car once, it produced a noise disappearing as the revs increased
Old Jan 16, 2013 | 07:04 PM
pitifulpluto's Avatar
I could be wrong, but I think you have a mercedez benz transmission as in the supercharger xk models. Be careful what fluid you use and call jaguar they will let you know what fluid you should be using.
I'd have to agree with the timing chain being the culprit of this noise.
Does the noise continue when the engine is warm and idling?
Old Jan 16, 2013 | 07:20 PM
clubairth1's Avatar
Community Influencer
No. Ford 5 speed. The same one in the Lincoln LS, Mustang and Explorer and others. Dead common as I said.
It uses Mercon. Again any store will have the correct fluid. Just look up your application.
Old Jan 16, 2013 | 08:16 PM
bfsgross's Avatar
ddyke, as others suggest: As a precautionary, service the trans. with new filter and fluid. Check catalytic converters for loose heatshield or decaying innards, causing them to rattle during idle. Check timing chain tensioners. They may have already been swapped with the updated metal tensioners.
Old Jan 17, 2013 | 09:34 AM
ddyke2000's Avatar
Is the transmission a sealed tranny. I cand find the dipstick, I looked in the owners manual and showed everything but the tranny dip stick. If it is a sealed tyranny how do I change filter and refill the fluid?
Old Jan 17, 2013 | 10:19 AM
JagV8's Avatar
The How Tos here are very detailed how to check/fill etc. But really DO WORRY about the chain tensioners as they are prone to failure especially with age. Also in the stickies.
Old Sep 30, 2014 | 09:06 AM
srchapman's Avatar
Default End Result?
I was wondering what your rattle by the torque converter ended up being. I don't see whether you ever diagnosed it. Could you please tell me because I have the same problem and I am 90% sure it must be the torque converter. I was hoping that it might not be. Thank you for your post.
Old Sep 30, 2014 | 09:24 AM
tbird6's Avatar
He is long gone as is the car!!
The Ford 5 speed does not have much if any TC problems. You will read about them on this forum but that is for the later S Types that have the ZF 6 Speed. That transmission has a known problem with the lock up friction material failing and it usually sets a code.
You have the 6 cylinder so you are good with the timing tensioner stuff.
Maybe a dust shield rubbing?
Old Sep 30, 2014 | 12:27 PM
abonano's Avatar
Make sure the bolts to the TQ to flex plate and crank are nice and tight...
Missing tooth or the starter gear touching the flex plate could e the culptret of the noise...
I had this issue on my 95 Trans Am... the only difference is the noise is not symmetrical and does not dissappear when the rev's are increased.
Old Nov 1, 2014 | 12:43 AM
omartinez29's Avatar
Default vibration inside and ticking outside
hi i have a 2005 jaguar s type the car runs great but it has a vibration when idling and a ticking sound under the hood what can i do here could itg be something simple ? help me guys
Old Nov 1, 2014 | 12:44 AM
its a v8
Old Nov 1, 2014 | 02:28 AM
JagV8's Avatar
At a guess a faulty purge or PCV valve but look at fuel trims for more data.
GordoCatCar
Jan 2, 2017 01:10 PM
martybmw
Apr 2, 2016 04:55 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
raulan
Sep 10, 2015 12:43 PM
