Rear brake only works during the day?
ok, you could try the usual, check the is no water in the boot affecting the Rear Electronic Control Module (RECM), and that you have no loose, damaged, corroded wires or connections between the RECM and you lights.
Hope this helps
Hope this helps
Wrong bulb or bad bulb. Easy fix and low cost. Get a list of all the bulbs in the tail lamps, and replace all of them. Should be had for less than $30.00. That is what I did. I know you expect the lamp warning to tell you but sometimes it doesn't. Be careful not to short the circuit on the body of the car if you change them while the battery is still connected. I speak from experience.
Thanks for the responses i have my eork cut out for me. Also at idle my car shakes a good bit and restricted performance pops up multiple times i was told i have a clogged cat and didnt know if that could cause the problem
Could be cat, could also be several things... plugs, coils, vacuum leak, dirty air or fuel filer, injectors, MAF, or even a air leak from a crack or not properly installed air box.... lol A bunch of little easy to fix things.
BrentGardner
29
Dec 16, 2024 12:13 AM
Robert1968
Jun 24, 2017 11:16 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
Oct 19, 2015 09:44 PM
