Recommend a good Jaguar tech in Southern NJ.
Old Apr 4, 2022 | 12:13 AM
ChappY41's Avatar
Default Recommend a good Jaguar tech in Southern NJ.
I have an 02 S type 3.0L. Car will start and run but when I shut it down such as stop at a store. When I come out after approx 15-30 mins. Car will crank but not run. If I wait 30-45 mins after the crank/no start it will fire up and run. Car will replicate this problem almost every time. If I disconnect battery and charge overnight. It will crank but not run. But when I wait 30mins later it will fire up and run.
Old Apr 4, 2022 | 02:02 AM
JagV8's Avatar
If you can use an OBD tool, have a look at the 2 temperature readings (ECT & IAT) when it's OK & when it's not.
Old Apr 4, 2022 | 02:29 AM
ChappY41's Avatar
I have an Autel AL629 i'll see what readings I get and let you know. Thanks
Old Apr 4, 2022 | 04:51 AM
S-Type Owner's Avatar
It may also be your "crankshaft position sensor" as these can fail and sometimes not throw a code. You also might also ask a Moderator to edit your thread topic, as not knowing any techs in the Garden State, I nearly gave the topic a "pass"... I am pretty sure others might do so as well.
Old Apr 6, 2022 | 02:24 AM
I've moved another of ChappY41's questions on this same topic:
https://www.jaguarforums.com/forum/s...isfire-257700/
Please continue the discussion in that thread to avoid duplication
THREAD CLOSED
mikega
Feb 28, 2025 10:24 AM
Hernan Quinonez
Nov 17, 2016 06:48 AM
X-TypeMentality
Feb 5, 2014 05:56 PM
JeffXType
Oct 27, 2012 08:58 PM
jsechri2
Aug 31, 2010 11:54 PM
