Replacement for busted water outlet pipe s-type 4.0 Jaguar part number AJ85884
Old Aug 11, 2025 | 11:31 AM
jagx2's Avatar
Default Replacement for busted water outlet pipe s-type 4.0 Jaguar part number AJ85884
Anyone have to replace a water outlet pipe for a 2000 S type 4.0?
The part seems impossible to find new or used. I’m wondering if the XJ8/XKR 4.0 L version would fit. It looks the same in photos, but one nipple is larger. If it otherwise fits, I figure I could modify a hose to compensate this size difference.
Water Outlet Pipe AJ85884
Top photo is s-type
Botttom photo is XJ8 version
Old Aug 11, 2025 | 01:01 PM
motorcarman's Avatar
The coolant outlet (heater feed for the AJ26/AJ27) is the only thing different about the outlet pipe you need. (AJ28)
I did not realize they were unavailable recently.
Wish I had known so I could have stocked a few for customers.(I have a few with AJ28 engines)
Old Aug 11, 2025 | 10:25 PM
jagx2's Avatar
Default Thank you motorcarman for your response and confirmation.
I was also shocked to know the part can’t be found in stock. Really didn’t want to go used since I figure if mine busted, other original ones may be getting fragile too. Going to give the XJ8 version a try.
Old Aug 12, 2025 | 10:03 AM
xalty's Avatar
aj27 outlet and a hose barb reducer. that or you use an aj30 outlet xw4z8a520af and drill + jb weld your coolant temp sensor in there
Old Aug 12, 2025 | 10:50 PM
Dejo's Avatar
I both my here https://www.jagpieces.com/
First i fix the old one with 2k epoxy. It held up 350 km till got home. Its very britle plastic after so many years.
Edit: Here you go!
https://www.jagpieces.com/tuyau-de-sortie-d-eau-s-type-v8-aj85884-c2x25179752
TAD
Jun 18, 2023 04:20 PM
WWW
Mar 22, 2021 01:53 PM
Stuart Satter
Mar 8, 2020 09:41 AM
tubeviper
Dec 28, 2014 04:01 PM
randyb
Aug 3, 2012 10:35 PM
