rod
Old Feb 12, 2014 | 10:24 AM
rodandsusie777's Avatar
Default rod
I a 55 plate s type 2,7 and the needle in the rev counter clicks but doesn't hardly move and isn't set to zero all other info in the dial ie computer is ok
Old Feb 12, 2014 | 10:29 AM
Injekter's Avatar
WTF?......did you read that back before you posted?
Old Feb 12, 2014 | 10:40 AM
Default Rod
It should have read I have a 2005 s type jaguar and the rev counter needle clicks but doesn't move and isn't set to zero hope someone can help Rod
Old Feb 12, 2014 | 10:54 AM
Injekter's Avatar
ok,,, now we are getting somewhere....: )
Old Feb 12, 2014 | 11:53 AM
Welcome to the forum Rod,
Did this just happen or did you get the car this way?
Have you tried the gauge check in Engineering Test Mode?
Please also post an intro in the new members section.
Old Feb 12, 2014 | 12:27 PM
Hi thank you for the reply It was a problem when I bought the car there were other problems but they are now sorted except for the rev counter .How do I test it thanks Rod
Old Feb 12, 2014 | 01:02 PM
Try here:
https://www.jaguarforums.com/forum/s...st-mode-35978/
Old Feb 13, 2014 | 09:13 AM
Cheers for link. The tachograph won't zero or read on red line just gets stuck in the 6 o'clock position. Any other ideas?
Old Feb 13, 2014 | 10:37 AM
JagV8's Avatar
Remove it and examine up close. Send away for repair if desired.
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
captbob73
Oct 24, 2015 05:49 PM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
Woznaldo
Sep 26, 2015 11:02 AM
