S-Type Heat issues
Old Dec 10, 2010 | 02:50 PM
expatjagman's Avatar
Default S-Type Heat issues
2000 S-Type 3.0 6
Getting no heat - I have searched this forum and see lots of discussion about DCCV - but I don't think that is my problem.
In the front of the engine bay there are three hoses connected to what appears to be a metal (alloy?) valve assembly, this is a T and appears to be in two halves bolted together - the top two hoses go into one side of the assembly, the bottom hose, the other side - then connects to a plastic piece (Is that plastic assembly the DCCV?) that in turn connects to two smaller hoses that go the heater?
What appears to be the issue is the valve? assembly described above - both upper hoses are hot, the lower hose is cold, as are the ones coming out of the plastic connector.
What is that "valve?" assembly called and what would the replacement part be?
Old Dec 10, 2010 | 03:32 PM
bfsgross's Avatar
A: Dccv
Old Dec 12, 2010 | 06:31 PM
what I'm looking at looks nothing like any of the pics of the DCVV and there are no wires or electronics on it.... Could some-one have replaced the DCVV with some other device?
Old Dec 12, 2010 | 06:57 PM
Sorry but we need to see what you are talking about IMHO.
Old Dec 12, 2010 | 08:26 PM
Gus's Avatar
Gus
I think this is what you are looking for. http://www.gusglikas.com/AutoRepairAC2000SType.htm This information will help you with the problems related to the Dual Climate Control Valve (DCCV) and assist you in troubleshooting. This link will get you to the onelines related to your car http://www.gusglikas.com/AutoRepairElectrical.htm I hope this helps.
Old Dec 13, 2010 | 06:53 PM
Gus I was thinking the same thing a picture tells a thousand words ... I'm out of town but when I get back I'll post a pic.
I checked on my 2003 V8 yesterday and found the DCVV. the part on the 2000 looks nothing like the link you provided!
Old Dec 14, 2010 | 01:23 PM
tbird6's Avatar
Be aware that the DCCV comes in a 3 hose and 5 hose version. Depends on the engine and the year. Also the Lincoln LS shares the same part. So first determine how many hoses your car has attached to the DCCV.
Old Dec 14, 2010 | 01:27 PM
Dirk Bailey's Avatar
Got the 3 hose version on autoparts.com for $82 the five hose version is much much more.
Old Dec 14, 2010 | 04:50 PM
tbird6's Avatar
That's true but you can't change which one your car came with!!
Well you got lucky because I paid almost $300 from Jaguar for the 3 hose version before I found out the Lincoln LS part would work.
Old Dec 14, 2010 | 10:01 PM
Yup, and Expats 2000 is gonna need the 5 hose version. But it pays to shop around.
Old Dec 14, 2010 | 10:15 PM
Gus's Avatar
Gus
I got mine from Amazon for $144.00
Old Dec 22, 2010 | 08:36 PM
Kapitan1975's Avatar
HI Gus,
does this also work on the 05 STR? i had heater problem ... not blowing hot (heated) air..... a/c in the other hand works fine (had warm weather in Houston last few days)
if i need to have it repaired ... how much do you think it will cost me....
Old Dec 23, 2010 | 03:16 AM
raygin's Avatar
Default ref - the heat problems
Seems quite a common fault with S types, I am currently suffering with roasting passenger side temperatures no matter what setting I use. I understand that the valve defaults to open when failed or more correctly when it has no power supplied to it. so my one sided roaster is probably due to failed solenoid coil or wiring fault. I have been advised to check the wiring loom and connectors leading to the valve (DCCV) as there are known issues with the front loom. Failing no fault found here - then it could be down to a faulty control module as it has been known that when a solenoid fails it can take out the output transistor on the control unit, this again is a common fault with the control modules and is easily diagnosed and repaired by a reasonably competent electrician - the part is also available. There is some useful information here =
http://jaguarclimatecontrol.com/diagnose/
Hope this is some help
Old Dec 23, 2010 | 09:20 AM
clubairth1's Avatar
Community Influencer
Kapitan1975:
Yes. You need the 3 hose version. I live in the Houston area and have a 2005 STR too. I changed it myself and it was starting to seep coolant but everything was still working fine. I used that opportunity to flush and change my coolant. I should have changed the thermostat too but did not have one at the time. I do now and will keep it in case I need it.
You can get the 3 hose version from Rock Auto for about $94. Just search for YG378. That is the Motorcraft part number. The other things people have posted are more rare. Do the simple stuff first. The DCCV will fail it's just a matter of time. I wonder if the replacement parts will last any longer?? On the LS board they seem to. I changed the DCCV on my 2003 Lincoln LS about 25K miles ago and still no problems.
If you have the dealer fix it I would estimate the cost to be somewhere in the $600-$1000 range. Maybe Brutal can jump in here. I am taking a wild *** guess based on Jaguar high prices. I was unaware of the Ford part and paid almost $300 for the same part in a Jaguar box!!!
Old Dec 23, 2010 | 10:40 AM
ccc's Avatar
ccc
$88 from amazon with free shipping, no tax
http://www.amazon.com/Motorcraft-YG3...3122259&sr=8-1
Old Dec 23, 2010 | 11:11 AM
Staatsof's Avatar
Now to find someone who will install it properly for $88 ...
Old Dec 23, 2010 | 01:58 PM
hi Clubairth1
thanks for the info.
was it hard to replace the unit? do i drain the coolant first?any electrical wire i need to remove?
thanks again
Old Dec 23, 2010 | 02:36 PM
JagV8's Avatar
Try the FAQ
Old Dec 24, 2010 | 11:20 AM
clubairth1's Avatar
JagV8 is right but I found it a bit tough to install. I drained the coolant so it would not go all over the place. Yes it has an electrical plug and the hoses and clamps are a pain.
I have attached a picture of the special tool I used on the clamps. It's called a cable clamp pliers. Without it I could not get to the clamps with my normal pliers and had several that I could not replace the clamp after I got it off. They are a bit pricey at around $40.
Old Dec 24, 2010 | 10:38 PM
01stype30's Avatar
Angry all heat all the time
I have a 2001 s-type 3.0 it just started having a climate control problem. All heat all the time no cool air either side (both sides hot air). By reading the threads it sounds like a DCCV problem. I searched for the valve online and it appears that my s-type has the 5 hose DCCV and it cost about $214.00 dollars. Does this seem about right or could the problem be else where? Also before the heat problem there was an odor that seem to be burnt electrical
