S type mechanical issue?
Old Jun 26, 2009 | 08:46 AM
JOsworth's Avatar
Is the fault light on. Are there codes? The other thing it may be is the timing chain. If it jumps, ect it can cause the poor run condition. If it really is a timing issue, it will get progressively worse until fixed. Another jump could kill the motor.
Old Jun 27, 2009 | 12:16 AM
How does he know? Has he done a compression test or is it just a guess?
Old Jun 28, 2009 | 07:13 AM
JOsworth's Avatar
Just a crazy thought. The early 4.0 engines had a reputation for bad timing chain tensionors. That would cause the timing to be off. If the timing is off wouldn't that cause a valve seat issue. I agree with Norri. The 4.0 is a real strong motor and something as severe as bent valves doesn't sound likely.
Old Jun 29, 2009 | 11:10 AM
JOsworth's Avatar
If it was bad enough I would think it could. I've seen some pretty crusty valves come out of engines before. If it is enough to prevent the valve from setting properly in the seat it would cause there to be a "bleed off" of pressure. I would let the Jag techs take a crack at it.
stanjag
Dec 29, 2024 08:26 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
ogorir
Sep 3, 2015 07:34 PM
97xj6lucy
Sep 3, 2015 07:44 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
