S-Type Randomly Stopped
Old Sep 16, 2020 | 06:08 PM
echaplin's Avatar
Default S-Type Randomly Stopped
My 2003 S-Type was running fine today until it randomly wouldn't start. Not too long before I put in some gas (93 grade as usual) and then drove it for a couple miles before parking it at my destination. I came back to the car about an hour later and tried starting it but it wouldn't work. The battery isn't dead and the car does turn over, but after that the engine will just rumble for a little and then stop. I tried pressing on the gas while starting it too but that doesn't make a difference. I think it might have to do with the gas I put in the tank or the PCM, but I'm not sure.
Old Sep 17, 2020 | 01:36 AM
JagV8's Avatar
PCM is last suspect.
If you've had lots of rain and not kept the drains clear then PCM is a suspect.
Far more likely is fuel pump / filter.
BTW what engine???
Old Sep 17, 2020 | 04:39 AM
wydopnthrtl's Avatar
If you think it could have been bad fuel.. try replacing the fuel filter. It's just behind the left front tire.
I had a problem of my engine dying. I was convinced it was a lack of fuel. But in the end it turned out to be a bad relay (that tested good w/a multi meter and power)
https://www.jaguarforums.com/forum/s...2/#post2245876
1234jen
Apr 22, 2020 10:03 PM
Amee Estevez
Jul 19, 2017 01:55 PM
pab
43
Feb 24, 2015 11:02 AM
rmocarski
Apr 13, 2010 05:48 PM
Treasures
Sep 2, 2008 11:40 AM
