S Type Rear Diff
Old Apr 8, 2019 | 03:37 PM
Wooford XJR's Avatar
Default S Type Rear Diff
Hello S-Type owners,
Would one of you a parts list for the rear diff in a S-type. I need factory part number for the axle shaft bearing and the axle shaft seals..
Thanks in advance.
Wooford XJR
Old Apr 10, 2019 | 05:12 AM
JagV8's Avatar
It's at the forum top or you can go to a forum sponsor.
There are others on the net.
Old Apr 10, 2019 | 07:50 PM
I looked, shows the seal but not the bearing. Jaguar doesn't not offer it, they want you to purchase a new diff.
Will keep digging.
Old Apr 11, 2019 | 12:48 AM
kr98664's Avatar
Have you disassembled the differential yet? Haven’t touched one from Jaguar, but have replaced bearings in other differentials, transmissions, etc. In almost all instances, the bearings originally came from Timken, Koyo, ITN, SBK, etc. I took the old parts to a bearing supply house, where they quickly matched them up with new, either by part number or dimensions. Same thing with seals, too.
Old Apr 11, 2019 | 06:55 AM
I have a Ford 8.0 with Limited Slip and 2:88 gears installed out of a Lincoln LS, the Lincoln drive shafts and a pair of S-Type R drive shaft that I want to install in my 2005 XJR.
The input shafts for the S-Type R are smaller diameter than the Lincoln drive shafts. So I was hoping to get some part numbers to check the inside and outside diameters.
I have a 2006 S-Type that I am parting (Cracked Block) but do not have the rear carriage out of it yet.
I will get to it eventually.
Thanks for your help.
Wooford XJR
Old Apr 15, 2019 | 06:33 AM
Panthro's Avatar
Try here. Keep in mind that the Gen 1 & Gen 2 differentials have no interchangeable parts besides the ring & pinion. You gotta do a complete swap of the rear axle assembly to use the Ford 8" LSD in a Gen 1 carrier, or just use a Quaife LSD in your stock Gen 2 diff carrier. Also, where did you find 2.88 gears?
Old Apr 15, 2019 | 06:38 AM
Panthro's Avatar
This thread should help some too
juha_teuvonnen
May 25, 2016 10:37 PM
jordannray
Feb 17, 2011 04:53 PM
tbird6
29
Nov 19, 2010 06:49 AM
Sixx Dogg
Mar 14, 2010 08:50 AM
bojangles
Jan 13, 2008 08:57 PM
