Shock Bolt Stuck- Help!
There are two bolts that can work depending on the length required:
- C2P5886 (M14 X 71mm)
- C2P7192 (M14 X 99mm)
2007. Bear in mind I removed the welded nut, so the thread didn't matter for me. I needed bolts that would fit the inner diameter of the bushing.
T
Not bad, I just ground out the weld with a cutting disc.
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
