Shock Bolt Stuck- Help!
Old Dec 31, 2018 | 10:12 AM
NBCat's Avatar
There are two bolts that can work depending on the length required:
  • C2P5886 (M14 X 71mm)
  • C2P7192 (M14 X 99mm)
Most likely the 71mm would fit your car, but you can measure it to be certain.
Old Dec 31, 2018 | 10:56 AM
ncbrit's Avatar
Originally Posted by jazzwineman
What year S-Type do you have? Those do not look to be a fit for my car, but then again I could be wrong.
T
2007. Bear in mind I removed the welded nut, so the thread didn't matter for me. I needed bolts that would fit the inner diameter of the bushing.
Old Dec 31, 2018 | 12:47 PM
jazzwineman's Avatar
I am curious-, not that I am going to do that, but how hard was it to remove the welded nut? It appears not to be a spot well and quite substantial.
T
Old Dec 31, 2018 | 01:05 PM
ncbrit's Avatar
T
Not bad, I just ground out the weld with a cutting disc.
Old Jan 1, 2019 | 09:03 AM
Prange's Avatar
Use the blue wrench.
Old Jan 1, 2019 | 10:36 AM
You will need to be more specific about the blue wrench. There appear to be a number of them.
TBB
Old Jan 1, 2019 | 11:59 AM
Prange's Avatar
TBB
I have an acetylene set-up.
Old Jan 1, 2019 | 06:06 PM
  #28
Got it I was being to literal in interpretation.
T
Flyboygus
Dec 7, 2017 04:18 AM
romello424
Mar 20, 2016 07:49 AM
Rutty
XJ40 ( XJ81 )
Nov 8, 2014 07:39 PM
H20boy
Mar 7, 2011 04:56 PM
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
