Take a look at this. this can't be right?
Old Jul 27, 2014 | 06:24 PM
2002jeff's Avatar
Default Take a look at this. this can't be right?
2002 jag S type. 3.0
so i have been hearing a slight rattle coming from under the car at low RPM's (thinking is might be a loose heat shield) so I jack her up to take a look. and I get down toward the transmission and now im getting close to the noise. and I look up to what I believe is the torque converter and I see this gear spinning around. I was like "WHAT".... this cant be good. so I turn the car off and get back under to take a closer look. looks like a cover plate is missing. the edges around the hole are smooth and look as if it was meant to be there but the cover may have fallen off and now is open to the elements.
so my question is to this Forum is. What the %*#@ is going on with my transmission/torgue converter? my trans is running and shifting fine. so what is going on and how do I fix this. also, isn't his supposed to have tans fluid in it. and if I can cover the hole, how do I get the right fluid into this. this one has got me scratching my head and with no answers.
thanks
Jeff
Attached Thumbnails Take a look at this. this can't be right?-imag1360.jpg   Take a look at this. this can't be right?-imag1362.jpg   Take a look at this. this can't be right?-imag1363.jpg   Take a look at this. this can't be right?-imag1078_1.jpg
Old Jul 27, 2014 | 06:41 PM
Lt0302's Avatar
Default Missing
A rubber plug/cover....for fluid change download jtis for instructions or search here on the forum or google it!
Old Jul 27, 2014 | 07:19 PM
2002jeff's Avatar
thanks for the response. can you be more detailed. I tried looking up rubber plugs for my 2002 jag s type and got nothing. sorry for the hassle.
Jeff
Old Jul 27, 2014 | 07:37 PM
abonano's Avatar
My cover disappeared after having a new rebuilt trans installed. If you find the part number - please share by all means... Thanks
Old Jul 28, 2014 | 01:54 AM
JagV8's Avatar
Is it going to be a Ford 5R55N part? If so maybe try
www.automaticchoice.com/Catalogue/5r55n.pdf
5R55N transmission parts,Ford 5R55N transmission parts
Old Jul 28, 2014 | 08:31 AM
2002jeff's Avatar
thanks, im chasing the part down now. will keep everyone posted when I find it and how to order one.
Jeff
Old Jul 28, 2014 | 08:44 AM
2002jeff's Avatar
thanks
Old Jul 28, 2014 | 08:54 AM
Here's the JTIS section showing the rubber plug in place in the top drawing and removed in the bottom one:
However, I can't find the rubber plug listed in the Jaguar Parts Catalogue!
Attached Thumbnails Take a look at this. this can't be right?-s-type-transmission.jpg
Old Jul 28, 2014 | 11:14 AM
xjrguy's Avatar
Cover, P/N C2C10161
Cheers,
Old Jul 28, 2014 | 12:52 PM
2002jeff's Avatar
found it.....well i should say that Gerry at jagbits found it. he can get them for $35.00 .....im ordering mine today
Attached Thumbnails Take a look at this. this can't be right?-7-28-2014-10-04-57-am.jpg
Old Jul 28, 2014 | 03:35 PM
abonano's Avatar
Good work Steve and Jeff. Check out SNG Barrett - they have them listed for $4.90 each (before forum discount) Just ordered 2 (just in case the cover is missing on my 04 XJ8 - this part is also compatable with the X350 models also)
Old Jul 31, 2014 | 03:02 PM
2002jeff's Avatar
Mission accomplished. thanks to gary at JAGBITS.com for all his help.
Old Jul 31, 2014 | 03:11 PM
jagbits's Avatar
Former Sponsor
The S-Type 3.0 part is different than the 8 cylinder XJ8 part, just FYI
Old Jul 31, 2014 | 05:13 PM
tbird6's Avatar
To answer your other question. It's just a dust cover/inspection port. No oil behind it as you found out.
Old Jul 31, 2014 | 06:38 PM
abonano's Avatar
Hi Gary, thanks for pointing this out - what would the part number would be for the 4.2 V8? Thanks for sharing
Also, to confirm - the C2C10161 part number is correct for the 4.0 V8
Old Jul 31, 2014 | 06:41 PM
abonano's Avatar
Weird... Jaguar INSPECTION COVER FOR TORQUE CONVERTER - C2C10161
Old Jul 31, 2014 | 11:19 PM
jagbits's Avatar
Former Sponsor
C2C10161 fits the V8 4.2 XJ8, XK8, XK and S-Types - part number XR852765 fits all 3.0 liter S-Types
Old Aug 1, 2014 | 09:17 AM
abonano's Avatar
Thanks for the clarification Gary
Old Aug 2, 2014 | 07:01 PM
mel's Avatar
mel
Default sound from gearbox/converter
Did the noise go away after replacing the rubber cover?
Old Aug 2, 2014 | 10:16 PM
2002jeff's Avatar
well yes and no. with the cover in place it is almost unnoticeable. but without the cover you can hear a, i hate to use this word...Growl... it must be coming from the torque converter or from withing the bell housing. it only "growls" at low RPM. as the RPM's go up the sound goes down. I say growl because its not a sound like a quarter in the dryer sound. its a loose part sound. im going to try to make a quick video of it and the sound and try to post it.
so as the torque converter becomes active, it stops growling/rattling? as i rev up the engine the noise is greatly reduced. i think there is a drain plug for the converter, so I was thinking of draining the oil. but then I dont know how to replace. sorry I new to some of this type of repairs. and dont want to make it worse.
Im giving a WAG now, but seems like something might be loose inside the converter?. or is this sound normal?
thanks for all the great posts.
Jeff
