Take a look at this. this can't be right?
Old Aug 3, 2014 | 04:01 PM
mel's Avatar
mel
Jeff
Thanks, i have the same sound coming from torque converter,will chk if the cover is missing during my days off.my s type is 2000/V8.
Old Aug 21, 2014 | 05:49 PM
abonano's Avatar
Originally Posted by 2002jeff
2002 jag S type. 3.0
so i have been hearing a slight rattle coming from under the car at low RPM's (thinking is might be a loose heat shield) so I jack her up to take a look. and I get down toward the transmission and now im getting close to the noise. and I look up to what I believe is the torque converter and I see this gear spinning around. I was like "WHAT".... this cant be good. so I turn the car off and get back under to take a closer look. looks like a cover plate is missing. the edges around the hole are smooth and look as if it was meant to be there but the cover may have fallen off and now is open to the elements.
so my question is to this Forum is. What the %*#@ is going on with my transmission/torgue converter? my trans is running and shifting fine. so what is going on and how do I fix this. also, isn't his supposed to have tans fluid in it. and if I can cover the hole, how do I get the right fluid into this. this one has got me scratching my head and with no answers.
thanks
Jeff
Guys, in Jeff's picture (Post #1) there's a round rubber piece or "grommet" on the bottom of the transmission bell housing. Does anyone know the part number?
I ordered the inspection cover and installed it today when I noticed this piece missing. I'm almost tempted to go to the transmission shop that installed my trans 2 years ago and go nuclear on them for leaving these out...
Any help would be appreciated...
Old Aug 21, 2014 | 06:21 PM
abonano's Avatar
Update - after some searching I came up with this Ford Part Number: E9TZ-7N171-A
Transmission Housing Grommet...
Old Aug 21, 2014 | 09:20 PM
abonano's Avatar
Another update:
Thanks to xjrguy - The Jaguar Part Number is: XR85619 (Plug)
Thanks!
TreVoRTasmin
Feb 23, 2021 03:13 PM
Johnken
Apr 8, 2018 10:21 AM
RaceDiagnostics
Apr 4, 2016 04:00 PM
Rocky15
Oct 12, 2015 03:42 AM
dmatthewman
Sep 30, 2015 10:10 AM
