Ticking under acceleration
Old Nov 16, 2018 | 02:20 AM
damurna7's Avatar
Default Ticking under acceleration
So I am in the process of sorting out a new-to-me 2003 STR and I have noticed that under hard acceleration there is a ticking noise that seems to come from the driver's side of the engine. It seems to go away when the car is at full operating temperature. Can't really localize where it is coming from any better than that because it only happens under load. Any thoughts on what it may be?
Old Nov 16, 2018 | 05:08 AM
SRT's Avatar
SRT
Could perhaps be pinking? That happens under load. Could be a hot spot or bad petrol. Hot spots could be spark plugs.
Highest octane petrol for starters and replace spark plugs if no success.
Could of cause be many other things.
Old Nov 16, 2018 | 06:00 AM
Datsports's Avatar
clogged catalytic converters are known to cause pinking or pre ignition on the STR and XJR 4.2.
it can also be bad plugs or coils or both .
Old Nov 16, 2018 | 12:55 PM
damurna7's Avatar
Forgive me if these next questions are dumb. I'm familiar with the concept of pinging, but have never experienced it in the real world. Would pinging be steady and linear or random? Also would it get better as the engine heats up or worse? When the ticking starts it is very steady and increases linear to RPMs. I'm running premium fuel, but haven't changed the plugs yet. I'll give that a try.
Old Nov 16, 2018 | 01:15 PM
jackra_1's Avatar
Pinging, pre-ignition, is usually steady and increases with rpm and gets worse as engine heats up.
Old Nov 16, 2018 | 01:39 PM
SRT's Avatar
SRT
On an automatic it is maybe not that easy, but the best condition for pinking is good filling and slow combustion. Wide open throttle at low rpm.
It might not disappear at high speed, but you can't hear it! If this, it leads to burns and holed pistons, if bad.
If only when cold, it could be piston slap. Sounds terrible, but harmless! Disappears when hot, if not too bad.
Old Nov 16, 2018 | 02:37 PM
Datsports's Avatar
it could also be a small exhaust flange leak.
Old Nov 16, 2018 | 04:40 PM
damurna7's Avatar
Cool. It goes away as the engine warms up, so doesn't sound like pinging. Is there a way to narrow down piston slap and what is the fix if that is it?
Old Nov 16, 2018 | 05:21 PM
jackra_1's Avatar
+1 on that.
May 7, 2023 04:58 AM
Wolfy
Jan 11, 2020 01:56 PM
ashbypa
Jan 5, 2018 07:15 PM
ahunt4
Apr 10, 2015 12:46 PM
wolvesfan
Mar 1, 2010 05:08 AM
