Timing off?
Old Mar 21, 2012 | 11:06 AM
  #41
jagstype01's Avatar
Han
Originally Posted by Brutal
^^^^ your trans shifter cable is streached and too loose to engage drive properly. Fix it now before you smoke the trans because it bleeds off line pressure when not fully engaged. You pull the center console and adjust with by loosening the 2 big nuts where the cable bolts to the shifter. You want even play on both sides of neutral so that neutral notch falls in the middle of the play.....follow?
Thank you ! I will try this first thing when I get home! Can't wait to have her back, if I only knew it would be this easy to fix her I would have done it same month when it all happened.
Old Mar 22, 2012 | 02:26 AM
  #42
jagstype01's Avatar
So I just came went straight to garage took off center console adjusted the two bolts and now everything is back to normal! Thanks a lot Brutal!
Old Mar 22, 2012 | 07:21 AM
  #43
Jon89's Avatar
Once again it is Brutal to the rescue. I'll wager that he has collectively saved us forum members at least fifty grand in repair costs over the past two or three years. Don't know what we would do without him....
Old Mar 22, 2012 | 09:20 AM
  #44
Brutal's Avatar
UH YEAH, AND I THINK ABOUT HOW MUCH MONEY I LOOSE SPENDING TIME ON HERE THROUGHOUT THE DAY. I NOW MAKE LESS HOURS IN DAY THAN IM HERE WORKING. AND TO THINK I USED TO BE 150% EFFICIENT. JUST THE TYPE WORK AND ECONOMY I GUESS. SHOULD HAVE STAYED A RECEPTIONIST IN THE MASSAGE PARLOR
Old Mar 22, 2012 | 12:58 PM
  #45
tbird6's Avatar
Well if you did would that include "Many Happy Endings"??
Old Jan 15, 2024 | 06:31 PM
  #46
Mike 8897's Avatar
Default Coils
Sounds like coil is bad . Funny the scanner should pick that up.
Old Jan 16, 2024 | 06:51 AM
  #47
JagV8's Avatar
Wow - ancient thread (near 12yr old)...
Torrid
16
Aug 5, 2014 03:50 PM
eharris917
Apr 4, 2012 09:52 PM
prey
Sep 15, 2011 01:53 PM
atom
Jul 19, 2011 05:43 PM
Hoggzman
XJ40 ( XJ81 )
Feb 16, 2011 12:39 PM
