Tire Pressure
Old Dec 23, 2012 | 11:34 PM
philbou's Avatar
Default Tire Pressure
Hi,
ont the stickers they recommend 32 psi front and 34 rear . Just change my tire any recommendation ?
Old Dec 24, 2012 | 03:05 AM
police666's Avatar
it depends on the speed you drive at and what load you have in the car, i like the way the car feels with 38 all round but that's just my preference.
Old Dec 24, 2012 | 09:02 AM
Mikey's Avatar
Originally Posted by philbou
Hi,
Follow the manufacturers recommendation.
Old Dec 24, 2012 | 09:41 AM
philbou's Avatar
Thanks , i see in some website they recomanded to put les in front .... is that true
Old Dec 24, 2012 | 10:13 AM
Mikey's Avatar
You're likely to see recommendations that are all over the map, but which one of them (if any) is a positive recommendation is a complete guess. I'd never go below OEMs spec without defining an actual need and understanding the consequences.
Old Dec 24, 2012 | 11:07 AM
police666's Avatar
have quick read of this
Tire Tech Information - Air Pressure/Load Adjustment for High Speed Driving
as long as you dont go under the oem psi or over the tire psi rating pick a psi that you feel balances comfort/handling.
Old Dec 24, 2012 | 01:07 PM
plums's Avatar
Agreed. There is more to tire inflation than "by the book".
For example on a X308, "by the book" would mean 42 psi on any brand tire other than the original factory issue Pirelli P-Zero. Clearly ridiculous, but "by the book".
As a matter of fact, going "by the book", the only allowable replacement tire is the factory issue Pirelli P-Zero.
Even, "the book" gives a range of inflation pressures depending on intended usage.
"the book" is a safe answer for the casual driver with no desire to look further ... it is not always the optimal answer.
If it were the fountain of all knowledge, there would be no need for places like JF.
Old Dec 24, 2012 | 02:28 PM
abonano's Avatar
Yes, 32 in front and 34 in the rear.
Old Dec 24, 2012 | 02:35 PM
philbou's Avatar
so 34 in front and 36 Back is reasonable?
Old Dec 24, 2012 | 04:32 PM
Gus's Avatar
Gus
I had so many problems with getting the right tire pressure on my XK8. It seemed I was replacing my tires because of center tire wear (over inflated) until I found the right pressure. However, on my S-Type I found the 32 – 34 works well. I now have 40,000mi on my tires and if it were not for a bad ball and 2 worn bushings on one side I would be getting at least another 15,000 on them. My driving has been 80% highway and 20% town. As others have suggested use the 32 – 34 psi it seems to be the right formula.
Old Dec 25, 2012 | 01:44 PM
abonano's Avatar
34/36 is reasonable - but I would advise against it as Gus pointed out above. Stick with 32 psi in front and 34 psi in the rear and check cold tire pressures weekly to obtain maximum usage on tires. Also, rotate every 6K miles...
Old Dec 25, 2012 | 02:06 PM
Mikey's Avatar
What are you attempting to achieve?
Old Dec 25, 2012 | 02:46 PM
philbou's Avatar
just won't to know what is the best
Old Dec 25, 2012 | 04:15 PM
Gus's Avatar
Gus
Read this and see if it helps.
Link HOW TO READ TIRE WEAR
silkcat
Jan 18, 2025 04:29 AM
amaezing
Sep 18, 2015 03:25 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
