transmission advise
Old Feb 16, 2011 | 03:16 PM
achysklic's Avatar
Default transmission advise
I have a 2005 s type 4.2
when I take off and the car shifts from 1st to 2nd it shifts really hard. After that it shifts smooths as butter.
Even if I start off really easy it shifts hard from 1st to 2nd. The Tranny doesn't slip no noise is noticed
Any ideas thanks.
Old Feb 16, 2011 | 04:06 PM
JagV8's Avatar
google
"the lurch"
I think it's in the FAQs but it's all over the forum in any case.
But - that only applies if your car is running right i.e. closed loop, good fuel trims, no misfires etc.
Old Feb 16, 2011 | 04:07 PM
Frank M's Avatar
Any ideas thanks.
The transmission software may just need to be reset to default.
Sometimes they develop a bad learn from a unique sequence of events.
you could drive it differently for a day or two to see if there is any difference.
Old Feb 16, 2011 | 04:26 PM
achysklic's Avatar
so driving it differently will reprogram the software? sorry to sound like a newbie.
Old Feb 16, 2011 | 05:34 PM
JagV8's Avatar
Don't count on it!!
Old Feb 16, 2011 | 05:42 PM
achysklic's Avatar
Thanks guys will unhooking the battery for alittle bit reset it? Or will unhooking it mess things up?
Old Feb 16, 2011 | 05:51 PM
JagV8's Avatar
It will just mess things up. It will not clear the tranny at all. Do the google thing and lots of reading
Old Feb 16, 2011 | 06:07 PM
Frank M's Avatar
It learns the way we drive and sets shift patterns accordingly.
As an example when I take my wifes 04 xj8 out for gas, the shifts can be slightly mushy.
After a few brisk hard accelerations it changes slightly to accomodate my style.
Not a huge difference but enough to be noticed.
In the OP case, he could start to see a difference. Mybe enough to give it more time and avoid getting it reset to default at the dealer. ($$)
Old Jul 25, 2011 | 07:05 AM
SteveJacks's Avatar
Hi Achysklic, I am wondering if you ever got your hard shift 1-2 resolved? I have a 2004 XK8 with this exact same thing. It isn't the downshift lurch from 2-1, but upshift from a stop from first into 2nd. All other shifts are perfect. I had the fluid/pan/filer changed by the dealership to stop the bark sound from 3-4 (and BTW, the dealer said that didn't fix it, so they found a bottle of the anti-bark additive from another dealer, and that did fix it), but this didn't fix the hard shift 1-2. I tried pulling the negative battery cable and touching it to the positive (left like that for 2 hours) and then doing the "adaptive reprgramming" driving sequence discussed within the forum, and that had zero effect. I hope someone has a definitive resolution to this. I don't want to pay the dealer for their troubshooting, rather point then to a TSB or something. Also, no codes or anything.
Old Jul 26, 2011 | 08:27 AM
JagV8's Avatar
Does the 2004 XK8 use the same gearbox (ZF 6HP26)?
Old Jul 26, 2011 | 08:34 AM
SteveJacks's Avatar
Yes, it is the same transmission.
Poet
Feb 7, 2025 02:18 PM
tomsjag
Jun 10, 2023 10:02 AM
kthrash
Feb 25, 2019 10:20 AM
ryan_border
Dec 23, 2015 04:27 PM
Poet
Oct 2, 2015 09:00 AM
