Transmission Fluid Help.....
Old Jan 13, 2014 | 07:10 PM
SlimGoody's Avatar
Default Transmission Fluid Help.....
Hi guys, I have a slight issue with my Stype and was wondering how will I know if my transmission fluid needs to be changed or is low? Thanks in advance
Old Jan 13, 2014 | 08:29 PM
Mmmm, 02 should be 6 speed ZF trans, but it could be the last of the 5 speed units, dunno.
Either way the fluid cannot really be inspected without draining some off.
The kms on the car may negate that thought, as anywhere around 100K kms (you can do the miles thing), BOTH trans manufacturers are recommending a fluid and filter change.
Old Jan 13, 2014 | 08:34 PM
motorcarman's Avatar
The 5R55N is a FORD gearbox. Jaguar used ESSO 999 fluid.
Do a search for compatible fluid (MERCON V ????)
bob gauff
Old Jan 13, 2014 | 10:51 PM
NBCat's Avatar
I have successfully used Mercon V in the 5R55N gearbox with no difficulty.
Old Jan 14, 2014 | 08:03 AM
abonano's Avatar
+1 on Mercon V - I also have used this fluid in my 5R55N gearbox after it's rebuild with no issues.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
picard
Oct 12, 2015 11:56 AM
SeanU
US Northeast
Sep 20, 2015 12:46 PM
chatmanx
Sep 11, 2015 07:17 PM
