Trouble code P1410 issue
I am unable to have my Jag emission tested due to the P1410 code which is Supercharger air cleaner additional air inlet actuator. I have checked the fuse and it's good the next item to check is the FH010 electrical connector but I don't know where it's at. I am hoping someone will be able to help me locate it.
If you are talking about the air box flap as i call it in layman's terms, it is visible by removing the air filter.....best bet is to remove the airbox and you can check things out...remove the supercharger inlet duct, the plastic upper radiator cover, the airbox inlet tube, then 1 bolt and the electrical connector to the flap actuator and take it out
OK I've gotten to the PCM electrical connector test I need to know where the PCM P101 connector is
hello harley01 i know its an old topic but i have the same problem .do you know if you did it get fixed ?and what the problem was? i have same car s type r s/c and also same p1410 code .it can help me a lot if you can remember how you fixed it.thanx Walter
Djschnei
22
Jun 5, 2013 11:33 PM
tbird6
Jan 10, 2010 02:49 PM
